2 - HMM - Installation
HMM - Operator's / Service Manual
  • 0 - HMM - Table of Contents
  • 1 - HMM - Introduction
  • 2 - HMM - Installation
  • 3 - HMM - Maintenance
  • 2.1 HMM Installation
HMM - Installation
Revision B - 6/2026
This procedure will guide you through the installation of the HMM 430.
Tools required:
  • 8mm and 17mm sockets
  • 24mm and 30mm wrench
  • 5mm, 4mm, 3mm, and a 2.5mm hex wrench
  • Machinist's Level
Note: The machine will arrive in one crate.
Download and fillout the HMM430 Installation Checklist prior to installing the machine.
Unpacking - HMM430
HMM430 will arrive in one crate as shown [1].
Unpack the crate to find the granite bed on one side of the pallet with the computer cart stacked on top of the base of the machine on the other[2].
Note: HMM is not directly fastened to the pallet. The machine is held down by straps that go over the x gantry that are strapped to the pallet.
Use a forklift to lift from the center of each of the following: computer cart [1], machine base [2], and granite bed [3].
Note: Machine Gross Weight is 1300lbs. This should require a forklift with a minimum capacity of 2000lbs.
Carefully rest the granite bed on top of the machines base.
Note: Make sure to fork the machine in the middle portion. Forking from the edges will interfere with placement onto the base.
Use a 2.5mm hex wrench to loosen the set screw found at [1].
Once the set screw has been loosened, slide the probe head into position [2], and then tighten the set screw to secure the head in place.
Shipping Bracket Removal - HMM430
Remove four shipping brackets that are attached to the machine.
  • 2 large brackets holding the Y in place [1].
    • 5mm Hex Wrench.
  • 1 small bracket holding the X, underneath the accordion cover [2]
    • 4mm Hex Wrench.
  • 1 small bracket holding the Z, on the back side of the column [3,4].
    • 3mm Hex Wrench.
Leveling - HMM430
Level the machine using a three point method. Raise one foot off the ground - recommend rear right. Lock down the opposite diagonal foot by tightening the larger locknut up against the base. ·
Level X & Y directions independently by adjusting the lower hex.
  • Torque the hex counterclockwise to lower the base. Torque the hex clockwise to raise the base [1].
    • 30mm wrench for locknut.
    • 24mm wrench for adjustment hex.
Electrical Installation - HMM430
Connect the following wires to the Renishaw SPA 3-2 Controller.
Note: The following drawings illustrates the two Renishaw controllers, as seen in the computer cart from top to bottom. The top controller is the Renishaw SPA 3-2, while the lower controller is the Renishaw UCC T3-2.
[1] X -Scale.
[2] Y - Scale.
[3] Z -Scale.
[4] MCU Lite - 2 Joystick.
[5] E-STOP.
[6] Limit.
[7] Ethernet Between T3-2 and SPA 3-2.
[8] X Motor.
[9] Y Motor.
[10] Motor Power Supply.
[11] Z Motor.
Connect the following wires to the Renishaw UCC T3-2 Controller.
[12] Probe.
[13] Ethernet to PC.
[14] Ethernet Between T3-2 and SPA 3-2.
[15] UCC T3-2 Power In.
Connect the following wires to the computer.
[1] Keyboard.
[2] Mouse.
[3] Ethernet between T3-2 and SPA 3-2.
[4] Microphone.
[5] CappsDMIS License Key.
[6] Audio.
Note: The computer will arrive with two items already connected: the orange Ethernet cable [3] and the green CappsDMIS license key [5].
SPA3-2 - Cable Diagram - HMM430
[1] X -Scale.
[2] Y - Scale.
[3] Z -Scale.
[5] E-STOP.
[6] Limit.
[8] X Motor.
[9] Y Motor.
[11] Z Motor.
UCC T3-2 - Cable Diagram - HMM430
[12] Probe.
Software Activation - HMM430
Updated
Note: To successfully activate the machine’s measuring software license key, refer to the HMM 430 Technical Documents. Download the folder titled SOFTWARE DOCUMENTS and complete the form titled Customer Registration Form for SMA. Once finished, send the completed document to the email address listed at the top of the document. The activation file will be emailed after the form is processed. The installing technician must have access to this file on site to transfer to the HMM430’s computer.
 Note: The customer registration takes at least one working day to review and process. It is highly advised that this be completed upon receiving notification of shipment, so that the software may be activated on the same day the machine is installed.
