5 - HVS - Maintenance
HVS - Operator's / Service Manual
  • 0 - HVS - Table of Contents
  • 1 - HVS - Introduction
  • 2 - HVS - Safety
  • 3 - HVS - Installation
  • 4 - HVS - Operation
  • 5 - HVS - Maintenance
  • 6 - HVS - Troubleshooting
  • 5.1 HVS Maintenance
  • 5.2 HVS Service Parts List
5.1 HVS Maintenance
HVS 1 - Maintenance
Revision A 05/2026
The following chapter will provide a guided walk-through on the maintenance for the Haas Vertical Saw - 1.
Table of Contents
  • HVS - Maintenance Schedule
  • HVS - Blade Install
Maintenance Item Interval
Clean off table Daily
Inspect blade condition Weekly
Inspect oil mist resevoir level Monthly
Replace saw blade As Needed
HVS Blade Install
Updated
Power [OFF] the machine.
Open the two access doors [1] on the left side of the machine.
With the saw blade [2] teeth facing left, place the blade over the two wheels [3], starting with the bottom driving wheel then the top after.
Check the blade is flush with the wheels. Tighten the blade tensioner knob [4].
Updated
Power [ON] the machine.
With the blade covers open, run the saw blade at a slow speed. Observe which direction the blade walks off the rollers.
Caution: Power [OFF] the machine before the blade derails.
Release the blade tension [4] and use the angle adjustment knob [5] to change the wheel angle. Tension blade after each adjustment.
Repeat this step until the blade can run for one minute without derailing from the wheels. Lock in the angle by tightening the locking handle [6].
HAAS Vertical Saw - 1 - Service Parts List
Revision C - 03/2026
Service Parts List
Part Number DESCRIPTION
93-5606 E-STOP BUTTON HVS-1
93-5608 SPEED ADJUST POTENTIOMETER HVS-1
93-5638 STATE INDICATOR LIGHT HVS-1
93-5526 VARIABLE FREQUENCY DRIVE (VFD) HVS-1
93-5470 POWER SUPPLY HVS-1
93-5465 HVS-1 SAFETY INTERLOCK SWITCH
93-5684 HANDLE MTLR GUIDE BLACK HVS-1
93-5685 BLACK HANDLE HVS-1
93-5686 BLACK HANDLE LEVER HVS-1
93-5687 FLEX COOLANT SPRAY PIPE HVS-1
93-5688 DISPLAY METER HVS-1
93-5689 SQUARE RELAY HVS-1
93-5690 CHIP CLEAN BRUSH HVS-1
93-5727 WORK LIGHT HVS-1
93-5728 DOOR HANDLE HVS-1
93-5729 HINGE BLADE DOOR HVS-1
93-5732 CIRCUIT BREAKER HVS-1
93-5733 AUX CIRCUIT BREAKER HVS-1
93-5905 TABLE GUIDE CASTING BLOCK HVS-1
93-5906 T-SLOT BAR ALUMINUM HVS-1
93-5907 PINION GEAR HVS-1
93-5908 TILTING RACK HVS-1
93-5909 TABLE SUPPORT BRKT BLCK RIGHT HVS-1
93-5910 80BLE SUPPORT BRKT BLCK LEFT HVS-1
93-6029 POWER LIGHT HVS-1
93-6031 TOP DOOR PANEL HVS-1
93-6033 DOOR LATCH HVS-1
93-6038 BLADE COVER LEFT HVS-1
93-6039 BLADE MOTOR ENCLOSURE HVS-1
93-6042 T-SLOT END CAPS HVS-1
93-6043 BLADE SPEED DIAL HVS-1
