4 - CL - Installation
Chucker Lathe - Operator's Manual Supplement
  • 0 - CL - Table of Contents
  • 1 - CL - Introduction
  • 2 - CL - Legal Information
  • 3 - CL - Safety
  • 4 - CL - Installation
  • 5 - CL - Control Icons
  • 6 - CL - Operation
  • 7 - CL - G-Codes
  • 8 - CL - M-Codes
  • 9 - CL - Settings
  • 10 - CL - Maintenance
  • 4.1 Chucker Lathe - Installation
  • 4.2 CL-1 Bar Pusher - Installation
The Chucker Lathe installation procedures are located on the Chucker Lathe - Interactive Service Manual.  Click on the image below.
Moving the Chucker Lathe:
Warning: The Chucker Lathe has a high center of gravity. Move the machine slowly and carefully to prevent it from falling over.
1. You will need a pallet jack that has at least 1500 lb capacity and forks that will fit in the space between the Chucker Lathe’s leveling pads (22.5", 571 mm).
2. Lift the Chucker Lathe from the control cabinet side.
3. Carefully move the Chucker Lathe to its operating location, then lower it onto the leveling pads.
4. Make sure there is equal tension on each leveling screws.
The Chucker Lathe Bar Pusher installation procedure is located below.
