10 - CL - Maintenance
Chucker Lathe - Operator's Manual Supplement
  • 0 - CL - Table of Contents
  • 1 - CL - Introduction
  • 2 - CL - Legal Information
  • 3 - CL - Safety
  • 4 - CL - Installation
  • 5 - CL - Control Icons
  • 6 - CL - Operation
  • 7 - CL - G-Codes
  • 8 - CL - M-Codes
  • 9 - CL - Settings
  • 10 - CL - Maintenance
  • 10.1 CL - Maintenance
Chucker Lathe - Maintenance
Regular maintenance is important to make sure that your machine has a long and productive life with minimal downtime. The most common maintenance tasks are simple and you can do them yourself. You can also ask your HFO about their comprehensive preventive maintenance program for complex maintenance tasks.
  • The linear guides and ball screws are automatically lubricated. The Chucker Lathe uses the Haas Axis Lubrication Oil system. Refill the axis oil canister as needed.
  • Manually lubricate the bar pusher piston bi-monthly. Use the manual feed switch to push the piston out of the pusher tube. Wipe off the piston with a clean cloth. Apply a thick layer of grease (SHC460 or Mobil 1 Synthetic grease) to the piston and insert it into the pusher tube.
  • Lubricate the collet and spindle contact points with a light coat of molybdenum grease (Haas p/n 99-0007 or Mobil p/n CM-P) once a month. Make sure collets are in good condition and free from burrs. Following this procedure will extend the life of the spindle/collet, and help prevent sticking.
