7 - Compact APL - Programming
Compact APL - Operator's Manual Supplement
  • 0 - Compact APL - Table of Contents
  • 1 - Compact APL - Introduction
  • 2 - Compact APL - Legal Information
  • 3 - Compact APL - Safety
  • 4 - Compact APL - Installation
  • 5 - Compact APL - Control Icons
  • 6 - Compact APL - Operation
  • 7 - Compact APL - Programming
  • 8 - Compact APL - M-Codes
  • 9 - Compact APL - Settings
  • 10 - Compact APL - Maintenance
  • 11 - Compact APL - Workholding
  • 7.1 Compact APL - Programming
Note: The above video showcases the full Mill APL, but most of the programming section can also be applied to the C-APL besides a few differences including the ones listed below:
  • The Compact APL has  Gripper Extend Delay in addition to the Gripper Clamp Delay.
  • The Compact APL does not have an AW Axis to jog, instead the gripper can be entended/retracted to get the position right in the AU/AV and X/Y planes.
APL Stop / Resume Feature
This feature lets you stop (interrupt) a running part program during an Automatic Part Loading cycle (APL Mode) and resume normal operation from any part in the program. The APL will not lose part count, and it will continue the part load and unload cycle.
Note: In order to pause an APL job, the following must be done.
  1. The part program must be stopped with any program stop command (M00, M01, M02, M30).
  2. The APL must reach the “At Ready” position before hitting reset.
 Note: If any of the following are done while an APL job is paused, the job will be canceled, and a new one will need to be started.
  1. Cycle power the machine.
  2. Change or edit APL jobs.
  3. Taking the control out of “APL Mode”.
  4. Interrupt the APL while the door is open and the arm is inside the machine
  5. Manipulate any APL mechanisms, such as the grippers/rotator.
  6. Jog any APL axis or select an APL axis for jogging.  Warning: If the last jogged axis was an APL axis pressing the handle job will cancel the APL job.
After resetting the control an operator may switch to MDI mode, EDIT mode,  JOG Mode to do any changes or part inspections as needed. All operation is normal at this point.
When the operator is ready to resume Part Machining in APL Mode. Press [MEMORY] and then put the cursor on the Tool Callout (e.g. T0505) where you want the program to start from. Do not start in the middle of the program since this may cause unintended motion.
With the control still in APL Mode press [CYCLE START] and resume part machining and APL operation.
