8 - Compact APL - M-Codes
Compact APL - Operator's Manual Supplement
  • 0 - Compact APL - Table of Contents
  • 1 - Compact APL - Introduction
  • 2 - Compact APL - Legal Information
  • 3 - Compact APL - Safety
  • 4 - Compact APL - Installation
  • 5 - Compact APL - Control Icons
  • 6 - Compact APL - Operation
  • 7 - Compact APL - Programming
  • 8 - Compact APL - M-Codes
  • 9 - Compact APL - Settings
  • 10 - Compact APL - Maintenance
  • 11 - Compact APL - Workholding
  • 8.1 Compact APL - List of M-Codes
This page gives detailed descriptions of the M-codes that you use to program your machine.
CAUTION: The sample programs in this manual have been tested for accuracy, but they are for illustrative purposes only. The programs do not define tools, offsets, or materials. They do not describe workholding or other fixturing. If you choose to run a sample program on your machine, do so in Graphics mode. Always follow safe machining practices when you run an unfamiliar program.
NOTE: The sample programs in this manual represent a very conservative programming style. The samples are intended to demonstrate safe and reliable programs, and they are not necessarily the fastest or most efficient way to operate a machine. The sample programs use G-codes that you might choose not to use in more efficient programs.
M-codes are miscellaneous machine commands that do not command axis motion. The format for an M-code is the letter M followed by two to three digits; for example M03. Only one M-code is allowed per line of code. All M-codes take effect at the end of the block.
Code  Description
M70 / M71 M70 Workholding Clamp / M71 Workholding Unclamp
M299 APL / Part Load / or Program End
