7 - VF-Pallet Pool - M-Codes
VF-Pallet Pool - Operator's Manual Supplement
  • 0 - VF-Pallet Pool - Table of Contents
  • 1 - VF-Pallet Pool - Introduction
  • 2 - VF-Pallet Pool - Legal Information
  • 3 - VF-Pallet Pool - Safety
  • 4 - VF-Pallet Pool - Installation
  • 5 - VF-Pallet Pool - Control Icons
  • 6 - VF-Pallet Pool - Operation
  • 7 - VF-Pallet Pool - M-Codes
  • 8 - VF-Pallet Pool - Settings
  • 9 - VF-Pallet Pool - Maintenance
  • 7.1 VF-Pallet Pool - List of M-Codes
This page gives detailed descriptions of the M-codes that you use to program your machine.
CAUTION: The sample programs in this manual have been tested for accuracy, but they are for illustrative purposes only. The programs do not define tools, offsets, or materials. They do not describe workholding or other fixturing. If you choose to run a sample program on your machine, do so in Graphics mode. Always follow safe machining practices when you run an unfamiliar program.
NOTE: The sample programs in this manual represent a very conservative programming style. The samples are intended to demonstrate safe and reliable programs, and they are not necessarily the fastest or most efficient way to operate a machine. The sample programs use G-codes that you might choose not to use in more efficient programs.
M-codes are miscellaneous machine commands that do not command axis motion. The format for an M-code is the letter M followed by two to three digits; for example M03. Only one M-code is allowed per line of code. All M-codes take effect at the end of the block.
Code  Description
M46 Qn Pmm Jump to Line
M48 Validate That The Current Program is Appropriate for Loaded Pallet
M50 Pallet Change Sequence
M199 Pallet / Part Load or Program End
