UMC Rough Leveling
Zero return each axis one at a time or press [POWER UP]. Go through the leveling process.
Repeat these steps to achieve correct machine level.
Adjust the (4) corner leveling screws to lift the casting off of the ground.
Set [H] to 4".
Turn both middle leveling screws [1] up off the middle pads.
Place the precision level [1] on one of the X-Axis linear guide.
First level the machine side to side. Lift or lower one side with even adjustments of the two screws [2] to center the bubble in the tool.
Place the precision level parallel to the Y-Axis on the linear guide.
Note:  You can also place a granite block across the X-axis linear guides, and put the precision level on top.
Adjust either the front or back screws evenly to level the machine front to back and center the bubble in the level tool.
