Tool Release Piston - Solenoid Service Kit - AD0403
Service Home How To Procedures Tool Release Piston - Solenoid Service Kit - AD0403
Recently Updated Last updated: 12/13/2023
AD0403
- Jump to Section - 1. Introduction 2. Festo Solenoid 3. AIRTAC Solenoid 4. SMC Solenoid Back to Top
The service part P/N 93-2852; SOLENOID AIR 3PORT 2POS 1 3/8NPT SERVICE is the replacement solenoid assembly for 93-5620 and 32-5620 solenoid valves. The replacement solenoid assemblies use solenoids from both Festo and SMC.
This can create confusion when assembling, since different solenoid manufacturers require different hardware and brackets from the service kit. Some hardware and 3/8" OD tubing may not be used at all. The bracket will also not be used for all applications of the new service kit
Each of the solenoid assemblies have the same cable connectors. Use the fittings from the removed assembly to make the correct configuration for your machine. Refer to the images below:
Reference the solenoid that is already in place and use the pieces in the kit to re-create a suitable replacement.
For machines that do not have a 40T gearbox and TSC:
Plumb the solenoid as shown.  Plug the unused 1/4 NPT ports.
For machines that have a 40T gearbox and TSC:
Festo Solenoid
  1. SHCS 1/4-20 X 1/2 LOW HD
  2. BRACKET SOLENOID VALVE TRP/AUTO JET
  3. TRP SOLENOID VALVE ASSY
  4. NIPPLE 1/4 NPT X 3 1/2 BRASS
  5. SHCS 10-32 X 1 1/2
  6. NIPPLE 1/4 NPT X 2 BRASS
  7. FITG NPT1/4M MUFFLER FREE FLOW
  8. FITG REDUCER NPT1/4F NPT1/8M STR BRASS
  9. FITG NPT1/4M PLUG STL
  10. HOSE 3/8 OD PE CLEAR
  11. HOSE 3/8 OD X .065 WALL PU 95A BLACK
AIRTAC Solenoid
  9. HOSE 3/8 OD PE CLEAR
  10. HOSE 3/8 OD X .065 WALL PU 95A BLACK
SMC Solenoid
IMPORTANT: At this time (12/2023) SMC solenoids have been phased out, and this image will be kept as REFERENCE ONLY
  5. PPHS 6-32 X 1 1/4
