CAN Spindle Head Bracket Replacement - AD0971
Service Home How To Procedures CAN Spindle Head Bracket Replacement - AD0971
5.2 CAN Spindle head Bracket-Replacement
Recently Updated Last updated: 05/22/2026
CAN Spindle Head Bracket - Replacement
AD0971
Revision A - 05/2026
This document provides instructions for replacing the CAN SPHD Bracket 28-0448 within the following subassemblies.
  • 32-1377 CAN SPNDL HEAD ASSY - MILL
  • 32-1647 CAN SPNDL HEAD ASSY - LATHE
This replacement kit 93-6348 is designed to solve the issue of plastic bracket fatigue caused by repeated removal and re-installation of the cover. The updated 28-0448A bracket incorporates 8-32 threaded inserts for cover attachment, providing a more durable and reliable mounting solution.
Kit Includes:
  • CAN ELECT SPHD PLASTIC BRKT W 8-32 INSRT
  • GASKET CAN SPHD ASSY
  • PPHS 8-32 X 1/2
  • PPHS 6-19 X 5/16 THREAD FORMING
Note: Both the original and replacement brackets require cover installation and removal using hand tools only. Power tools must not be used.
Replacement Procedure
Disassembly:
Remove 3x PPHS 8-32 x ½ [1] from front of assembly.
Remove 2x SHCS 10-32 x 3/8 [5] from front of bracket [3].
Remove 4x PPHS 6-19x5/16 [4] to disconnect the PCB from bracket [3].
Installation:
Install new GASKET CAN SPHD ASSY [2] and new CAN ELECT SPHD PLASTIC BRKT W 8-32 INSRT.
Install new 4x PPHS 6-19 x 5/16 THREAD FORMING screws [4] to attach PCB to bracket.
Reinstall 2x SHCS 10-32 x 3/8 [5].
Install new 3x PPHS 8-32 x ½ [1].
