CL-1 Waycover - Replacement - AD0848
Service Home How To Procedures CL-1 Waycover - Replacement - AD0848
Recently Updated Last updated: 03/03/2026
CL-1 - Way Cover - Replacement
AD0848
Revision A - 3/2026
- Jump to Section - 1. Introduction 2. X and Z Way Cover Removal 3. X and Z Way Cover Installation Back to Top
This procedure demonstrates how to replace the X and Z way covers on CL-1 machines. To replace the way covers, you must order the correct kit. Go to the Way Cover - Troubleshooting Guide to troubleshoot the way covers.
Note: Pictures in this procedure are used for reference only.
Note: Make sure to clean any chips/deris from way covers before insalling new ones.
Note: This procedure is for both regular and stainless steal way covers.
The following procedure applies to the following service kit.
  • 93-1001205  - WAYCOVER FIELD INSTALL KIT CL-1
Jog machine to the middle of the Z axis and jog X axis all the way forward.
Remove [1] FBHCS 1/4 - 20 x 1/2, attaching table skirt to table. Image 1.
Remove table skirt [1] ends and [2] sides. Image 2.
Remove shoudler bolts [1] 1/4 X 1/2 10-32 connected to spring and floater way cover.
Jog machine all the way to the left in the Z axis.
Remove [1] BHCS 10-32 x 3/8 from Z axis right side way cover.
Remove way cover.
Jog machine all the way to the right in the Z axis.
Remove [1] BHCS 10-32 x 3/8 from Z axis left side way cover.
Remove [1] FBHCS 1/4 - 20 x 1/2 from Z axis left side way cover.
Remove way cover.
Jog machine all the way forward in the X axis.
Remove bottom cover on X axis back way cover [1] BHCS 10-32 x 3/8.
Remove [2] FHCS 10- 32 x 1/2 from X axis back way cover.
Remove way cover.
Jog machine all the way to the back of X axis travel.
Remove [1] FHCS 10- 32 x 1/2 on X axis front way cover.
Remove way cover.
Jog machine all the way back in the X axis.
Install X axis front way cover with floater and spring.
Install [1] FHCS 10- 32 x 1/2. Image 2
Jog machine all the way forward in X axis.
Install X axis back way cover along with floater cover and springs attached.
Install [2] FHCS 10- 32 x 1/2 for X axis back way cover.
Install bottom cover on backside. [1] BHCS 10-32 x 3/8.
Install Z axis left side way cover.
Install [1] BHCS 10-32 x 3/8 for Z axis left side way cover.
Install [1] FBHCS 1/4 - 20 x 1/2 for Z axis left side way cover.
Install Z axis right side way cover.
Install [1] BHCS 10-32 x 3/8.
Attach springs to shoulder bolts.
Install shoulder bolts [1]  1/4 X 1/2 10-32.
Install table skirt [1] ends and [2] sides. Image 1
Attach table skirt using [1] FBHCS 1/4 - 20 x 1/2. Image 2
