Collet Closer - Replacement - CL-1
Service Home How To Procedures Collet Closer - Replacement - CL-1
Recently Updated Last updated: 05/06/2019
AD0399
- Jump to Section - 1. Parts Required 2. Collet Closer - CL - Replacement (2 steps) Back to Top
Parts Required
93-2832 QTY: 1
COLLET CLOSER CYL SRV KIT CL-1
Disconnect the main air supply and remove the airlines to the cylinder.
Remove the cylinder assembly in this order:
  1.  Switch Plate
  2.  Handle Bolts
  3.  Mounting Block
  4.  Cylinder Assembly
Assemble the cylinder (air fittings and clevis), and install in this order:
  1. Mounting Block
  2. Cylinder Bracket
  3. Cylinder Assembly
  4. Handle Bolts
  5. Switch Plate
Connect the airlines to the cylinder and connect the main air supply to the machine. Cycle the collet closer.
Adjust the collet closer with the clevis [6]. The closer is properly adjusted when the handle hesitates and makes an audible "pop" during clamping, then continues to the end of the piston stroke (as seen when a part is not in the collet).
