Desktop Mill - Vise - Installation - AD0559
Service Home How To Procedures Desktop Mill - Vise - Installation - AD0559
- Jump to Section - 1. Introduction 2. Installation 3. Maintenance Back to Top
Recently Updated Last updated: 08/04/2021
AD0559
This procedure will show you how to install the vise on a Desktop Mill. This document and service kit apply to all Desktop Mills.
Parts Required:
  • 93-1000726 Desktop Mill Vise Kit
  • 99-0677 Blue Mobil Grease
1. Clean the mounting surface.
2. Slide (2) M6 nuts [1] into selected slots in the mounting plate before installing the support block [2] by sliding mounting brackets into the mounting plate.
3. Secure by inserting (2) M6 screws [3] through the support block and nuts before fastening.
4. Install the moving block [3] by sliding mounting brackets into the mounting plate.
5. Slide (2) M6 nuts [1] into selected slots in the mounting plate before installing the static support block with insert [2] by sliding mounting brackets into the mounting plate.
6. Slide in (2) M6 screws [3] through the support block and nuts before fastening.
7. Install vise screw [4] through insert and second static support block.
  • Apply a thin coating of rust preventative to all machined surfaces of the vise.
  • Clean off all chips from the vise after each use.
  • Apply 99-0677 Blue Mobil grease (or equivalent) to vise screw as needed.
