E-Stop - Debounce - AD0546
Service Home How To Procedures E-Stop - Debounce - AD0546
Recently Updated Last updated: 03/22/2023
E-Stop - Debounce
AD0546
- Jump to Section - 1. Introduction 2. Installation (2 steps) Back to Top
This procedure tells you how to install the debounce capacitor onto the I/O PCB of machines with the auxiliary e-stop. When the e-stop is shaken there may be a momentarily disconnect that causes an e-stop of the machine, this debounce capacitor filters out the disconnect.
This procedure applies to and requires the following kits:
  • 93-3325 AUX E-STOP KIT
Machine Requirements:
  • 34-3490A/B NGC IO BOARD SIO-A/B CCA
WARNING: This procedure does not apply to I/O PCB board P/N 34-3490C as the E-Stop Debounce circuit is built into the board.
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Locate TB1 [1] on the I/O PCB Board inside the control cabinet.
Find pin7 [2] and pin12 [1] of TB1.
Properly connect the debounce capacitor [3] to TB1 [4].
