E-Vise - Motor Replacement - AD0488
Service Home How To Procedures E-Vise - Motor Replacement - AD0488
Recently Updated Last updated: 05/03/2022
AD0488
- Jump to Section - 1. Introduction 2. Installation (5 steps) Back to Top
This procedure shows you how to replace the motor on E-Vise (V1) first generation.  This procedure does not apply to V2 generation E-Vise.
 This document applies to the following service kits:
  • 93-3177 E-VISE MOTOR Assembly
Remove the motor cover[1] and two screws[2] to access the motor assembly.
Remove the two screws[1] behind the motor bracket.
Remove the two motor bracket screws[2].
Pull the motor assembly[3] away from the vise and remove the seal[4] when you remove the motor assembly.
Remove the four screws[1] mounting the motor[2] to the motor bracket
Mount the new motor[1] to the motor bracket.
Install the motor assembly[1] and install the seal[2] between the sheet metal enclosure and the vise.
Replace the motor cover.
