    2. Українська
    2. Українська
GM-2 Installation
Service Home How To Procedures GM-2 Installation
GM-2 Installation
Recently Updated Last updated: 11/14/2023
GM-2 - Installation
AD0798
Revision A - 09/2025
This procedure will detail how to install a GM-2 machine. For instructions on how to install the GM-2-5AX please refer to the GM-2-5AX Installation procedure.
Additional Tools:
  • T-2181: CNC DUAL LEVELING TOOL
  • T-2192: LEVELING ADAPTER UMC-750
Moving the Machine
The center of mass is depicted in the image for reference while attempting to move the machine.
Please follow the information found in the technical documents section of the machine information page GM-2 machine information for further information on how to prepare for moving a Haas machine.
Leveling Screws Hardware
Note: The washers [1] and nuts [2] are installed during shipping and should be saved for installation and not be discarded.
Note: The washer orientation [3] is important.  The conical part of the washer should be against the casting,  see illustration.
Remove Rust Inhibitor
To safely and effectively remove rust inhibitor from way covers and other non-painted surfaces:
Initial Scraping
  • Use a plastic scraper to remove the bulk of the rust inhibitor.
  • Avoid using metal tools to prevent scratching or damaging the surface.
 Important: Do not use scotch-brite or metal scrapers, these will scratch the way covers.
Chemical Cleaning
  • Spray the affected areas with a heavy-duty citrus cleaner or Simple Green.
  • Ensure full coverage of all non-painted surfaces coated with rust inhibitor.
Soak Time
  • Allow the cleaner to soak for several minutes to loosen remaining residue.
Wipe Down
  • Use a clean shop towel to thoroughly wipe off the softened rust inhibitor.
Rust Proofing
  • Apply mineral spirits or WD-40 to all exposed metal surfaces to prevent future rust formation.
Important: Always wear gloves and eye protection when handling chemical cleaners. Dispose of used towels and cleaning agents according to local environmental regulations.
 Important: To avoid any contamination of the way cover seals with the sticky residue. Do not move any of the axes until all the rust inhibitor has been removed.
Rust Inhibitor - Safety Data Sheet (SDS)
Control Install
Install the pendant cable arm [1].
Route the pendant harness [2] through the arm and attach the harness retainer [3].
Install the pendant arm cover. [4]
Route the pendant cables [1] into the pendant [2] and install the cable harness retainer.
Connect the cables to the SKBIF PCB. Refer to VMC - Pendant - Installation step 2 for connections.
Install the back cover [3].
Attach the  pendant assembly to the pendant stand [4].
Install the dome plugs [5]
Electrical Installation
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
Initial Control Inspection
Danger: At this point, there should be no electrical connection to the machine. Electrical panel must be closed and secured. When main switch is on, there is HIGH VOLTAGE throughout the electrical panel (including the circuit boards and logic circuits) and some components operate at high temperatures. Therefore, exercise extreme caution when working in the panel.
  • Set the main breaker switch at the upper right of the electrical panel on the back of the machine to OFF.
  • Using a screwdriver, unlock the two latches on the panel door, unlock the cabinet with the key and open the door.
  • Take sufficient time to check all the components and connectors associated with the circuit boards. Look for any cables that have become disconnected, look for any signs damage and loose parts in the bottom of the panel box. If there are any signs that the machine was mishandled, call the factory before proceeding.
1-Phase Machines: Insert each power lead into the wire cover.  Connect the two power leads to L1 and L3 terminals on top of the main circuit breaker.
3-Phase Machines: Insert each power lead into the wire cover.  Connect the three power leads to L1, L2 and L3 terminals on top of the main circuit breaker.
Connect the separate ground line to the ground bus to the left of the terminals.
For 3-phase machines, check to see what type of power configuration is supplying the machine. Take voltage measurements of each power lead to ground line. Then refer to RD0084 - Input Power Configurations to determine which power lead should be connected to the L1 terminal based of the voltage readings and power configuration.
Refer to Haas Main Circuit Breaker - Torque Specifications for what value to torque the circuit breaker power leads.
 Note: Make sure that the leads actually go into the terminal-block clamps . (A poor connection will cause the machine to run intermittently or have other problems, such as servo overloads.) To check, simply pull on the wires after the screws are tightened.
After the line voltage is connected to the machine, make sure that main circuit breaker (at top-right of rear cabinet) is OFF . Remove the Lockout / Tagout and Turn ON the power at the source. Using a digital voltmeter and appropriate safety procedures:
1-Phase Machines: Measure the AC voltage across L1 & L3 at the main circuit breaker.  The AC voltage must be between 220 - 250 volts .
Note: Lower or higher than this voltage can generate low/high voltage alarms.
3-Phase Machines : Measure the AC voltage between all three pair phases at the main circuit breaker.
The AC voltage must be between 195 and 260 volts (360 and 480 volts for high voltage option).
SMinimill - Reboot: The AC voltage must be between 198 and 242 volts for machines without a high voltage transformer.  Refer to the Minimill/SMinimill - Identification document.
 Note: Wide voltage fluctuations are common in many industrial areas; minimum and maximum voltage supplied to a machine while it is in operation must be known. U.S. National Electrical Code specifies that machines should operate with a variation of +5% to -5% around an average supply voltage. If problems with line voltage occur, or low line voltage is suspected, an external transformer may be used. If you suspect voltage problems, voltage should be checked every hour or two during a typical day to be sure it does not fluctuate more than +5% or -5% from an average.
Important: With the main circuit breaker turned OFF.
Check the transformer taps at the bottom-right corner of the rear cabinet.
1-Phase Machines: The input voltage cable must be moved to the connector which corresponds to the average voltage measured in the above step.
3-Phase Machines:  The input voltage cables labeled 74, 75, and 76 must be moved to the terminal block triple which corresponds to the average voltage measured in the above step.
Transformer T5 supplies 24VAC used to power the main contactor. There are two versions of this transformer for use on a 240 and 400V machines. The 240V transformer has two input connectors located about two inches from the transformer, which allow it to be connected to either 180-220V or 221-240V.
Users that have 220V-240V RMS input power should use the connector labeled 221-240V, while users with 190-220V input power should use the connector labeled 180-220V. Failure to use the correct input connector will result in either overheating of the main contactor or failure to reliably engage the main contactor.
The 480V (option) T5 transformer has three input connectors, labeled 340-380V, 381-440V and 441-480V.
Users with 340-380V 50/60Hz power should use the 340-380V connector while users with 380V-440V 50/60Hz power should use the 381-440V connector.
Important: Set the main circuit breaker to ON. Check for evidence of problems, such as the smell of overheating components or smoke. If such problems are indicated, immediately set the main circuit breaker to OFF and call the factory before proceeding.
After the power is on, measure the voltage across the bottom terminals on the main circuit breaker. It should be the same as the measurements where the input power connects to the main breaker. If there are any problems, check the wiring.
Apply power to the control by pressing the Power-On switch on the front panel.
Check the DC Voltage and AC Line Voltage gauges in Diagnostics. The DC Voltage gauge must read between 310 - 360V. The AC Line Voltage must be between 90 and 105 percent. If the voltage is outside these limits, turn off the power and recheck steps 2 and 3. If the voltage is still outside these limits, call the factory.
Electrical power must be phased properly to avoid damage to your equipment. The Power Supply Assembly PC board incorporates a "Phase Detect" circuit with neon indicators. When the orange neon is lit (NE5), the phasing is incorrect. If the green neon is lit (NE6), the phasing is correct. If both neon indicators are lit, you have a loose wire; check the connections. Adjust phasing by setting the source power to off and then swapping L1 and L2 of the incoming power lines at the main circuit breaker.
Danger: ALL POWER TO CNC MUST BE TURNED OFF LOCKOUT-TAGOUT AT THE SOURCE PRIOR TO ADJUSTING PHASING. ALWAYS DOUBLE CHECK THE INCOMING LINES WITH AN AC VOLTAGE DETECTOR.
Turn off the power and set the main circuit breaker to OFF. Close the door, lock the latches, and turn the power back on.
Remove the key from the control cabinet and give it to the shop manager.
Activation
When the machine is properly placed and connected to both air and electrical power, it is ready for final installation (removing shipping blocks, leveling, spindle sweep, etc.) and software activation. The HFO service technician does this. Contact the local HFO to schedule the work.
IMPORTANT:  Machines equipped with motion sensors must be rough‑leveled before attempting to arm the motion sensor.  For detailed instructions, refer to Service Notification - SA0007.  Access to this document is restricted to Haas Factory Outlet personnel.
Connect Air Supply
Connect the air supply at the lube panel.
NOTE: For air requirements refer to the decal that is located on the lube cabinet door.
Install Column Covers
  • Install the provided column cover ENCL PANL PAN LIFT ACCESS M VF as shown using 4 x FBHCS 1/4-20 X 1/2 LOCTITE screws.
  • Install the two provided column vent covers SP HD TOP BACK COVER VENT UMC as shown using 2 x FBHCS 1/4-20 X 1/2 LOCTITE screws for each.
  • Install the provided column cover ENCL PANL COLUMN COVER as shown using 3 x FBHCS 1/4-20 X 1/2 LOCTITE screws.
Install the Enclosure Panels
Install the enclosure frame over the tool changer and secure it to the bridge using four 1/2-13 bolts and washers.
Refer to the Haas Fastener Torque Specifications for the correct torque value
NOTE: The weight of the frame weldment is approximately 160 lbs. Use the forklift or other lifting device to lift the frame.
Install the front enclosure frame tubes [1] as shown on the picture.
Use the following hardware [2] to secure the frame tubes:
  • 8X SHCS 3/8-16 X 3"
  • 8X NUT 3/8-16 HEX
  • 16X WASHER 3/8 HARD
NOTE: A GM-2-5AX is shown in the image, but the steps will be the same for the 3AX
Install panels 1-6, (front and left side)
1 - ENCL PANL LEFT TOP COLUMN GM-2
2 - ENCL PANL FRONT CENTER GM
3 - ENCL PANL FRONT CENTER GM
4 - ENCL PANL FRONT LT GM
5 - ENCL PANL LT GM
6 - ENCL PANL REAR GM
Install panels 1-2, (left / back)
1 - ENCL PANL BACK LEFT TOP GM-2
2 - ENCL PANL BACK LEFT BOTTOM GM-2
Install panels 1-3 (left / bottom)
1 - ENCL PANL LEFT PAN GM
2 - ENCLOSURE SPLASH GUARD FRONT LEFT GM
3 - ENCL PANL LEFT BOTTOM COLUMN GM-2
Install the splash guard [1].
Install chip auger chutes [2]. Refer to the  Chip Auger - Installation steps 5 and 6.
Put the magnets [1] on the two brackets at every other space.
Place the brackets with the magnets on the inner surface of the front of the enclosure [1] and onto the back of the bridge [2]
. Caution: The magnets pull the brackets onto the bridge with strong force. Do not put your fingers between brackets and the bridge or you may injure your fingers.
Attach the vinyl curtains [1] to the brackets [2] using the 1/4-20 x 1/2" BHCS.
Move the brackets up or down to adjust the distance of the curtains from the table.
Install Safety Sensors
Install the safety sensors on each corner of the moving enclosure.
  • [1] Rear left safety sensor is 33.5" long.
  • [2] Front left sensor is 50" long.
  • [3] Front right sensor is 18" long with 29 ft cable.
  • [4] Rear right sensor is 18" long with the 17 ft cable.
Route the safety sensor cables.
  • The 33-0606 [1] cable is routed through the left side column from the factory. Connect the 33-0606 to the rear left  safety sensor.
  • Route the 33-0626 [2] cable from the rear left to the front left safety sensor.
  • Route the 33-0624 [3] cable from the front left to the front right safety sensors.
  • Route the 33-0623 [4] cable from the front right to the rear right safety sensor.
Rough Level
Before first power on, rough level the machine.
IMPORTANT : For dual ballscrew machines it is important to rough level before a first power on, as not doing so might cause the machine to alarm out during the X-axis during the zero return process.
  • Adjust the leveling screws to raise the machine 3" (H) from the floor.
  • Place the bubble level on the center of the table parallel to the Y-Axis. Adjust the leveling screws to level the table.
 NOTE: The image shows a carpenter level, this is for REFERENCE ONLY.  Please use a machinist level to rough level the machine
  • Place a bubble level on the center of the table parallel to the X-Axis. Adjust the leveling screws to level the table.
Remove Shipping Brackets
To unblock Y axis:
  • Remove the Y axis shipping bolts [1] that secure the Z axis sub plate [2] to the bridge.
To unblock the X axis:
  • Remove two hardware that secure the X axis shipping bracket [1] to the gantry column and the table.
  • Remove the shipping bracket [1].
  • Reinstall the table bolts.
  • Perform the same steps to remove the shipping bracket on the other side of the gantry.
To unblock the spindle head:
  • The machine must be power on.
  • Do not power up reset/zero return the machine
  • After initial start up press [SETTING] and navigate and set setting 53 JOG WITHOUT ZERO RETURN to TRUE.
  • Raise the Z-axis until the spindle is out of the shipping bracket [2] and remove the shipping bracket from the table.
Zero Return
 Danger: The safety edge sensors are not active when the machine is in handle jog mode. If the X-axis gantry is handle jogged into an obstacle the collision will not be detected by the safety edge sensors.
  • After the machine is powered on, cycle the door and the [EMERGENCY STOP] button.
  • Verify that there are no obstacles in the way of each axis and the shipping brackets have been removed, then press [POWER UP] and follows the prompts on the controller.
Fine Tuning Level/Adjusting for Twist
  • Attach the level tool to the spindle, with the tool facing as shown in the image.
  •  Jog the X axis to either end of the base and read the measurements.
  • Adjust the leveling screws as need be to raise or lower a corner of the base until the bubble closely match end to end.
  • Readings are NTE 0.0002 in (0.005 mm) over the full travel.
After leveling, complete the latest Inspection Report on HBC and attach it to the machines history.
 Note: This site is available only to Haas Service Techs.
GM-1/2 Inspection Report EA0455
