VMC - Pendant - Installation - AD0287
Service Home How To Procedures VMC - Pendant - Installation - AD0287
- Jump to Section - 1. Introduction 2. Pendant Installation - VF (3 steps) 3. Pendant Installation - DC-Series (4 steps) Back to Top
Recently Updated Last updated: 03/27/2026
Revision 2
AD0287
Revision C - 3/2026
This procedure shows how to install the pendant on the following machines:
  • VF-1 thru VF-12 machines
  • DC-1 and DC-2 machines
The pendant is installed during machine installation on these machines.
Updated
Attach the storage cabinet [2] to the right side of the machine.
Pull the pendant cables [1] to the left side of the cabinet.
Put the pendant spacer [7] onto the storage cabinet. Put the pendant [6] onto the spacer.
Attach the shoulder screw [9] and the washer [8] to the pendant.
NOTE: The pendant hardware such as the spacer, shoulder screw, and washer used in this step may be located in the RJH box.
Attach the swivel bracket [5] to the top of the storage cabinet.
Split the cables [3] evenly in between the two studs [4].
Put the cables into the pendant.
Updated
Make sure the cables stay inside the swivel bracket and carefully slide the cover [1].
Install the screws through the holes on top of the pendant cover [2].
IMPORTANT: When installing the cover, verify no cables are being pinched.
Note: The cover is different for VF-1/2 machines.
Remove the rear panel of the pendant. Connect these cables:
  • Remote Jog handle cable [1] to P9
  • Power cable [2] to J20
  • USB cable [3] to J9
  • Ethernet cable [4] to J28
Note: The remote jog handle is factory installed in VF-6 thru VF-12 machines. It is optional for VF-1 thru VF-5 machines.
Install a ferrite [5] onto the USB cable [3] connected to SKBIF J9 connection.
Install a ferrite [5] on the touchscreen cable [6] connected to SKBIF J11 connection.
 NOTE: Make sure to loop the USB cable within the ferrite [5] as shown.
Attach the ground wire [7] from pendant to the control cabinet.
 NOTE: Recommended to attach the ground wire to the cable clamp as not all screws in that area can be used for grounding.
Fasten the top bracket [1] and the bottom bracket [2] that secure the pendant to the enclosure panel [3].
Use 2 BHCS to secure the top bracket, and 3 BHCS to secure the bottom bracket.
Feed the cables [4] coming from the top of the enclosure through the top bracket so that they can be connected to the pendant.
Note: Make sure the hose for the operator blow gun [5] is fed through the bottom bracket [3]. See next step for connecting blow gun fittings to the bracket
Note: Do not damage the cables when fastening the top bracket. Feed the cables through before fastening the bracket if needed.
Install the top bracket cover [1] using the 4 BHCS [2] to fasten the cover to the top bracket that is attached to the pendant.
Secure the bottom of the pendant to the mounting bracket by fastening it with a SHCS [3] from underneath the bracket.
Make sure the rubber spacer [4] is in between the pendant and the mounting bracket. Place the one washer on each side of the rubber spacer.
Note: Make sure the top bracket cover doesn't pinch any of the cables that go to the SKBIF PCB.
Install the fittings at the bottom mounting bracket for the operator blow gun.
Attach the air hose [2] coming from inside the enclosure (routed in step 1) to the check valve [3].
Fasten the elbow fitting [1] to the check valve with the mounting bracket in between to secure the fittings in place.
Install the cover to the lower bracket to protect the fittings.
Attach the operator blow gun to the elbow fitting [1].
Remove the rear panel of the pendant to gain access to the SKBIF PCB.
Make sure to connect all the cables that were routed through the top pendant mounting bracket that was installed in the previous step.
  • Connect 33-4521 to the connector of 33-1300 which is connected to J20 [1] on the SKBIF PCB.
  • Connect the USB cable to J9 [2] of the SKBIF PCB.
  • Connect the ethernet cable to J28 [3] on the SKBIF PCB.
  • Connect the USB from the touchscreen assembly to J11 [4] on the SKBIF PCB.
  • Connect the ground wire to the cable clamp fastener [5] as shown in the image.
Note: Make sure that the ferrite filters [6] are installed onto the USB cables to protect them from electrical noise.
Once the wiring has been verified, reinstall the rear panel of the pendant.
