HA5C Indexer - Backlash Test
Service Home How To Procedures HA5C Indexer - Backlash Test
Recently Updated Last updated: 11/29/2018
- Jump to Section - 1. Tools Required 2. HA5C Indexer - Backlash Test Back to Top
Tools Required
  • Dial Indicator with Magnetic Base
  • Magnetic Test Bar
  • 3/8" Hex Socket
  • Full-Grip Collet
  • 3/8" Breaker Bar
Install a collet tool [1], a 3/8" hex socket [2] into the spindle.
 Note: Make sure the collet tool [1] is very tight to prevent the 3/8" hex socket [2] from moving during the backlash test.
Put the magnetic test bar [3] on the left side of the spindle.
Put the dial indicator on test bar [3] approximately 1" (2.54 cm) from the center of the spindle.
Use the breaker bar to push up the spindle [4] at about 15 ft-lb (20 N-m), and then release. Set the indicator dial to 0.
Use the breaker bar to push down the spindle [5] at about 15 ft-lb (20 N-m), and then release.
If the indicator shows more than 0.0005" (0.01 mm), the adjustment of the spindle backlash is necessary.
For this adjustment you must send the rotary to a certified rotary repair facility.
For instructions on where to find a rotary repair facility and how to send your rotary unit, go to  www.haascnc.com .
