HPC-1000 TSC-1000 - Auxiliary Filter - Coolant Filter - Maintenance
Service Home How To Procedures HPC-1000 TSC-1000 - Auxiliary Filter - Coolant Filter - Maintenance
Recently Updated Last updated: 11/29/2018
- Jump to Section - 1. Introduction 2. Parts Included 3. HPC-1000 TSC-1000 Auxiliary Filter - Coolant Filter - Maintenance (2 steps) Back to Top
Too much contamination in the Through-Spindle Coolant (TSC) or High-Pressure Coolant (HPU) auxiliary coolant filter (ACF) is a frequent cause of low coolant flow through the spindle. This procedure tells you how to replace the bag filter in the ACF.
If the ACF tank has a pressure gauge, perform this procedure before the pressure shown on the gauge decreases to 10 psi when in operation. If the ACF does not have a pressure gauge, perform this procedure one time per month.
Parts Included
93-9130 Quantity: 1
FILTER, BAG #2 25 MICRON
TSC:
Open the (4) latches [4].
Run this code in MDI mode:
M88;
No TSC:
Disconnect the hoses [1].
Drain the Auxillary Coolant Filter (ACF) tank into the coolant tank.
Reconnect the hoses [1].
After the tank is drained, clean or replace the bag filter [2].
Apply a thin layer of grease to the inner seal of the filter cover [3].
Install the filter cover [3] by closing opposite latches [4].
Push [MDI] Push [COOLANT] to operate the coolant pump until the ACF tank is full.
