HRP-1 - Extended Table - Field Installation - AD0581
Service Home How To Procedures HRP-1 - Extended Table - Field Installation - AD0581
Recently Updated Last updated: 12/06/2021
AD0581
- Jump to Section - 1. Introduction 2. Remove Original Template (1 step) 3. Relocate Robot Mount (1 step) 4. Install Extended Table (2 steps) Back to Top
This procedure will show you how to install the Extended Table on a HRP-1 stand and relocate the robot mount.
This document applies to the following kits:
  • 93-1000764 - ROBOT PKG-1 EXTENDED TABLE FIELD INSTALL
Note: Any existing programs need to be redone after relocating the robot on the stand and installing the extended table.
Remove the original template and hardware from the stand.
If installing the Extended Table on old version stand. Place the robot mount in the following location. This position is measured from the center of the robot mount hole to the edge of the table.
[1]    4.506 inches
[2]    2.525 inches
Use the mount holes as a template to center punch the locations of the clearance holes for the mount hardware.
Remove the mount and drill a 7/16" hole at the center punch locations.
If installing the Extended Table on old version stand. Install the extended table to the stand.
Use the template mount holes[1] to center punch the locations of the clearance holes for the template hardware.
Remove the table and drill a 7/16" hole at the center punch locations.
Remove the four socket head cap screws from the side panel and install the gussets using the included 1/4-20 X 3/4 socket head cap screws.
Install the extended table to the stand and gussets.
Install the extended templates to the table.
