HRP-2 - Dual Gripper Manifold - Installation - AD0612
Service Home How To Procedures HRP-2 - Dual Gripper Manifold - Installation - AD0612
Recently Updated Last updated: 04/12/2022
AD0612
- Jump to Section - 1. Introduction 2. Manifold Assembly Installation (8 steps) Back to Top
This document and service kit applies to Haas Robot Package 2:
  • 93-1000825 HRP-2 DUAL GRIPPER CABLE UPDATE KIT
Required for robots built before 05/01/2022.
Unplug the air line and remove the single gripper solenoid cable from the connection on the arm. Remove the solenoid from the bracket. Remove the single gripper solenoid bracket.
Assemble the manifold assembly.
Remove the Serial Number tag from the single gripper bracket and install to the dual gripper bracket with the supplied hardware.
Install the manifold assembly nd cable clamp to the bracket.
Install the bracket assembly to the robot arm.
Install the solenoids to the manifold.
Route the hose from each solenoid to the grippers through the conduit.
Plug the air line into the solenoid manifold push-to-connect fitting and install the dual gripper solenoid cable to the 24 pin connection on the arm.
