Pallet - Replacement - VMC
Service Home How To Procedures Pallet - Replacement - VMC
Recently Updated Last updated: 11/30/2018
- Jump to Section - 1. Introduction 2. Pallet - Replacement - VMC Back to Top
Tools Required:
  • Hoist
  • Straps or Chains
  • Eyebolts (2)
Prerequisites:
Make sure the machine is level before you do this procedure.
 Caution: Be careful when changing out pallets, each pallet weighs aprox. 300lbs.
 Note: Pallets that have been replaced must be re-aligned to the receiver.  Pallets shipped with the VMC from from the factory have been machined perpendicular to the spindle. It is recommended that replacement pallets be machined after aligning them to the receiver.
  1. Remove the old pallet from the APC using the supplied eyebolts and a hoist.
  2. Set the new pallet on the APC, aligning the roller grooves on the bottom of the pallet with the rollers on the APC.
  3. Loosen the clamp rail bolts on the new pallet. (the bolts should be snug and not overtightened)
  4. Run the new pallet into the receiver. Clamp and unclamp the pallet a few times (this will allow the pallet to center on the guide pins). Torque the clamp rail bolts to 50 FT-LB while the pallet is clamped to the receiver.
 Important: New pallets should be machined on the VMC in order for them to be perpendicular to the spindle.
