Renishaw Probe - WIPS - OMP40-2 - Settings
Service Home How To Procedures Renishaw Probe - WIPS - OMP40-2 - Settings
Recently Updated Last updated: 05/06/2025
Overview
The probe has (3) LEDs. This lets you see one of the LEDs from each side of the probe. The (3) LEDs operate as one. The LEDs flash in different colors and different lengths of time. The sequence that the LED flashes tells you the probe settings.
The LEDs flash these colors:
  • Red
  • Green
  • Blue
  • Yellow
  • Purple
The LEDs flashes a short or a long time. In the tables that follow, a small colored circle shows that the LED flashes a short time . A rectangle shows that the LED flashes a long time .
Look at the probe LEDs. Record the color and length of time that the LED flashes.
The meaning of the color and the length of time that the LED flashes is important. Refer to the table for the meaning.
The probe settings are in (4) groups,
  1. Switch-Off Method
  2. Enhanced Trigger Filter
  3. Optical Transmission Method/Probe Identification
  4. Optical Power.
LED Check
The probe does a check of the LED. It does this before it shows the values of the settings.
The LED flashes in this sequence: Probe State:
, ,  The LEDs operate correctly.
Switch Off Method
, ,  Switch off method is set to optical off. This is the initial setting for Haas machines.
, ,  Switch off method is set to short timeout (12 seconds).
, ,  Switch off method is set to medium time out (33 seconds).
, ,  Switch off method is set to long timeout (134 seconds).
Enhanced Trigger Filter Setting
, ,  Enhanced trigger filter is set to OFF. This is the initial setting for Haas machines.
, ,  Enhanced trigger filter is set to on.
Optical Transmission Method / Probe Identification
, ,  Legacy start filter is set to OFF.
, ,  Legacy start filter is set to ON.
, ,  Probe 1 is active. Usually the spindle probe is probe 1. This is the initial setting for Haas machines.
, ,  Probe 2 is active. Usually the table probe is probe 2.
Optical Power
, ,  The optical power level is set to the low power level.
, ,  The optical power level is set to the standard power level. This is the initial setting for Haas machines.
Battery Status
Probe State:
, , , ,  The battery is good.
, , , , , , , , ,  The battery is low.
