Secondary Spindle - Hydraulic Union Drain Hose - Replacement - DS-30 - Lathe - AD0130
Service Home How To Procedures Secondary Spindle - Hydraulic Union Drain Hose - Replacement - DS-30 - Lathe - AD0130
Recently Updated Last updated: 01/17/2019
AD0130
Applies to machines built from: April, 2014
- Jump to Section - 1. Introduction 2. Parts Required 3. Secondary Spindle - Hydraulic Union Drain Hose - Replacement (10 steps) Back to Top
This procedure tells you how to replace the drain hose on the hydraulic union when it has oil leaks because of kinks in the hose.
Parts Required
  • DS-30 Secondary Spindle Hydraulic Oil Drain Kit: P/N 93-2231
Press [POWER OFF].
Remove the enclosure covers shown to get access to the drain hose assembly on the hydraulic union drain.
Disconnect the drain hose on the hydraulic union at both ends.
Use a pipe wrench to remove the drain pipe assembly on the hydraulic union.
Install the new fitting onto the hydraulic union.
Install the new drain pipe onto the fitting in the position shown and hand tighten.
Use a wrench to tighten another 1/8 to 1/4 turn.
 Note: For clarity, the anti-rotation bracket is not shown.
Hand tighten the other new fitting onto the end of the new drain pipe.
Hold one wrench in position [1] while you turn another wrench [2] counterclockwise another 1/8 to 1/4 turn.
Install the new drain hose onto the hydraulic union at both ends.
Press [POWER ON].
Press the [RESET] button twice to activate the hydraulic power unit.
Make sure there are no leaks.
Press [POWER OFF].
Tighten the leaking fitting another 1/8 of a turn.
Repeat until there is no leakage.
Press [POWER ON].
