ST-10/15 - Tailstock Splash Guard - Installation - AD0423
Service Home How To Procedures ST-10/15 - Tailstock Splash Guard - Installation - AD0423
Recently Updated Last updated: 11/28/2018
Applies to the ST-10/15 machines with the tailstock that was build from Jan 2018 to Dec 2018
AD0423
- Jump to Section - 1. Introduction 2. Remove the Original Splash Guard (1 step) 3. Install the New Splash Guard (3 steps) Back to Top
This procedure explains how to replace an existing splash guard with an improved one to address the coolant leaks in the chip conveyor area.  The splash guard is located inside the machine's work area directly behind the tailstock.
  • For the machines built from January 2018 to to September 2018 use the 93-2942 Tailstock Splash Guard Kit.
  • For the machines built from September 2018 to December 2018 use the 93-2943 Tailstock Splash Guard Kit.
The kits have minor differences but the installation process is the same.
Remove three bolts [1] that secure the original splash guard [2] to the enclosure panel.
Remove the splash guard [2] from the machine.
Put the new splash [1] guard in place.
Install three mounting bolts [2].
Install the covers [2] on the back of the new splash guard [1] as shown in the picture.
Leave the mounting bolts [3] loose.
Spread the covers [1] to minimize the gaps [2] between covers and the machine's casting and tighten the mounting bolts.
Seal the remaining gap with the RTV.
Note: Refer to the Lubricant, Grease, and Sealant Tables for Haas Machine Components.
