TSC Check-Valve Bracket - Replacement - EC-400/500 - AD0170
Service Home How To Procedures TSC Check-Valve Bracket - Replacement - EC-400/500 - AD0170
Recently Updated Last updated: 01/18/2019
AD0170
Applies to machines built from: March, 2015
- Jump to Section - 1. Parts Required 2. TSC Check-Valve Bracket - Replacement - EC-400/500 (4 steps) Back to Top
Parts Required
  • EC-400/PP TSC Check Valve Bracket Kit (P/N 93-2266)
Press [POWER OFF].
Set the main circuit breaker to the OFF position.
Find the TSC check-valve assembly [2].
Find the bracket [1] for the check-valve assembly .
Remove the bracket.
Put the hose clamp [2] onto the check valve assembly.
Attach the replacement bracket [1] to the motor shroud.
Put the hose clamp [3] against the motor shroud as shown.
Find the hole [5] on the hose clamp.
Put a mark [4] at the location of the hole.
Remove the check valve assembly.
Remove the fan assembly [1].
Drill [2] a 0.281" (7.14 mm) hole at the location of the mark [3].
Use (2) screws to attach the bracket [1] for the check valve assembly.
Use (1) screw and (1) nut to attach the hose clamp [2].
Install the fan assembly [2].
