Umbrella Tool Changer - Mechanical Switches and Proximity Sensors - Maintenance
Service Home How To Procedures Umbrella Tool Changer - Mechanical Switches and Proximity Sensors - Maintenance
Recently Updated Last updated: 11/26/2018
- Jump to Section - 1. Mechanical Switches and Proximity Sensors - Maintenance Back to Top
Pieces of material or other contamination can prevent the operation of mechanical switches or proximity sensors. This procedure tells you how to clean mechanical switches or proximity sensors for a 10-pocket umbrella tool-changer. The illustration shows mechanical switches and proximity sensors, but a machine has only one type.
10-Pocket Carousel
  1. Mechanical switches
  2. Proximity sensors
  3. Carousel motor sensors (2)
  4. Shuttle motor sensors (2)
  5. Sensor Bracket
  6. Areas that must be cleaned
Push EMERGENCY STOP when you do maintenance on the machine.
Remove the mechanical switches or proximity sensors [3] from the motor plate. Remove all metal chips and debris from the mechanical switches or proximity sensors [3]. Clean the area [6] around the mechanical switches and proximity sensors [3] with a clean towel.
Remove both the IN and OUT mechanical switches or proximity sensors [4] and clean them. Clean the area [6] around the sensor bracket [5] and shuttle motor sensors [4].
Install the parts in the opposite order they were removed.
20-Pocket Carousel
  4. Carriage
  5. Cam follower assembly
  6. Shuttle motor sensors (2)
  7. Slip clutch
  8. Areas that must be cleaned
Remove the mechanical switches or proximity sensors [3] from the motor plate. Remove all metal chips and debris from the mechanical switches or proximity sensors [3]. Clean the area [8] around the mechanical switches and proximity sensors [3] with a clean towel.
Disconnect the carriage from the slip clutch [7]: Remove the hardware [5] from the carriage [4]. Manually push the carriage to each side to access both the IN and OUT mechanical switches or proximity sensors [6]. Remove the mechanical switches or proximity sensors [6] and clean them.
