UMC - Tool Brush Retrofit Kit - AD0794
Service Home How To Procedures UMC - Tool Brush Retrofit Kit - AD0794
- Jump to Section - 1. Introduction 2. Installation (5 steps) Back to Top
Recently Updated Last updated: 03/20/2025
AD0794
This procedure is to replace the tool changer brushes on UMC machines to reduce the tool change brush gap. A narrow brush gap will be more effective in brushing off chips during a tool change.
Note: This will require an additional helper to ease the retrofit process.
This procedure applies to the following kits:
  • 93-4612 SMTC BRUSH EXTENDER SVC KIT UMC-500
  • 93-4617 SMTC BRUSH EXTENDER SVC KIT UMC LARGE (UMC- 750/1000/1250/1500-DUO)
 Note: The Service kits apply to the machines listed above and their series.
Move the B-Axis trunnion as shown and move Y-Axis to move the Spindle Head furthest away from working area to have access to the tool changer brushes.
Press [E-stop].
Remove the brushes by removing the (6) screws.
Using the (3) screws, install the brush [1] included in the kit to the bracket [2].
Use the (3) screws to install the other brush included in the kit to the SMTC Internal Cover.
Install the bracket using the (3) screws [1].
Using the bracket as a template, use a 5/16” drill bit to make the (4) holes [2] through the sheet metal to add the (4) screws [2].
NOTE: Additional help will be needed to hold the hex nuts in place through the tool changer window while tightening the (4) screws [2] from the inside of the machine.
 NOTE: Machines that have a 70 Pocket Side-Mount Tool Changer have to use (2) self-tapping screws [3]. This is due to having no clearance to add the hex nuts on the screws that are trapped by the 70 Pocket SMTC.
