Axis Lubrication System - Restrictor Flow Grease - RD0009
Service Home Alarm Search: 134 Axis Lubrication System - Restrictor Flow Grease - RD0009
Recently Updated Last updated: 10/16/2025
RD0009
- Jump to Section - 1. Introduction 2. Identification Back to Top
Note: The location of the grease reservoir is different on some machines.
The restrictor-flow grease minimal lubrication system pumps grease through flexible plastic tubing and copper tubes to the axes.
Identification
Use the illustration to identify the parts of the lubrication system.
Note: For recommended lubricant types, see Lubricant Table for Haas Machine Components.
  1. Grease Reservoir Assembly - Stores the grease.
  2. Grease Filter Wrench - Removes the grease reservoir.
  3. Axis-Lube Air Solenoid - Pressurizes the grease reservoir [1].
  4. Air-Lube Panel Decal - Shows the color-coded cables that connect each solenoid.
  5. Oil Reservoir - Stores the oil that lubricates the spindle.
  6. Air Pressure Gauge - Shows the pressure (in psi and bar) at which the air is supplied.
  7. Air Manifold Assembly - Supplies air to the machine.
Main Distribution Manifold
  1. Main Distribution Manifold - Sends grease to the axis manifolds.
  2. Main Distribution Manifold Pressure Switch - Monitors the grease supply pressure and sends a signal to the control to generate an alarm if the pressure drops below the minimum level too quickly.
The grease reservoir lubricates the axes at a rate of (1) grease cycle for every 1000 meters of travel.
On some machines with this lubrication system, the grease reservoir lubricates the axes at a rate of (1) grease cycle for every 24 hours of axis motion.
Grease moves from the grease reservoir [1] through flexible plastic tubing to the main distribution manifold [2].
The main distribution manifold [2] sends grease to the axis manifolds [3].
Note: The amount of axis manifolds may be different on some machines.
Note: Each axis has (4-6 ) linear guide trucks [4] and (1) ballnut [5].
Grease moves from the axis manifold through copper tubes. The copper tubes lubricate the linear guide trucks [4] and the ballnut [5].
Note: There is (1) copper tube that goes to the ballnut and (1) copper tube that goes to each linear guide truck.
The restrictor flow grease lubrication system uses restrictor fittings [1] and adapter fittings [2] in the axis manifolds. The linear guide trucks use adapter fittings [3].
Note: Adapter fittings are smaller than restrictor fittings and do not restrict the flow of grease.
Note: The copper tubes on this system are not equal length.
Caution: Do not change the length of the copper tubes or flexible plastic tubing. This changes the flow of grease.
