Remote Jog Handle - Troubleshooting Guide - NGC - TG0119
Service Home Remote Jog Handle - Troubleshooting Guide - NGC - TG0119
- Jump to Cause - Back to Top
20.4 RJH - Troubleshooting Guide
Recently Updated Last updated: 10/14/2025
TG0119
Revision B - 6/2025
Alarm 546 SERIAL KEYBOARD BUFFER OVERFLOW, or none of the functions of the RJH work. There is a bad connection at the RJH Serial Keyboard Interface PCB or at the Maincon/MOCON. Check the cables and connections.
There is a faulty Serial Keyboard Interface PCB. Test the RJH for issues.
Machines with SKBIF Version 6.xx.  Alarm 546 SERIAL KEYBOARD BUFFER OVERFLOW. The SKBIF firmware is outdated. Make sure you have SKBIF firmware version 6.6 or higher.  Refer to SKBIF PCB / RJH Firmware Update - NGC procedure.
The Jog Handle pulse encoder does not generate axis movement. There is a faulty or contaminated Jog Handle Pulse Encoder. Check the jog handle for signs of contamination or physical damage.
Remote Jog Handle Touch - The machine motion when jogging is jerky when using the 0.010" or 0.100" increments. The remote Jog handle is outdated Update the RJH-Touch firmware to the latest version.  Refer to SKBIF PCB / RJH Firmware Update - NGC procedure.
Alarm 9421 RJH EMERGENCY STOP SWITCH ERROR The E-STOP jumpers JP2 & JP3 on the SKBIF PCB are in the horizontal position. Orient the E-STOP jumpers to the vertical position on the SKBIF PCB to enable the RJH E-STOP. Cycle power the machine to clear the alarm.
Docking or undocking the RJH is not detected by the machine. The magnet on the back of the RJH or the cable is faulty. Inspect the magnet behind the RJH holster to verify that it is correctly placed. Navigate to Diagnostics > Keyboard I/O and locate RJH OUTPUT #9 ON_HOOK. When the magnet aligns correctly with the RJH the ON_HOOK output will toggle from 0 to 1.
