System Messages & Notifications - Troubleshooting Guide - TG0139
Service Home System Messages & Notifications - Troubleshooting Guide - TG0139
Recently Updated Last updated: 10/15/2025
TG0139
- Jump to Cause - 1. System Messages & Notifications Back to Top
The 20000 alarms are informational messages only. These are usually generated at power up and only show in the alarm history. This information is used by our software developers for debugging purposes. This is an informational message only; no parts need to be replaced. They typically do not require any service action. The exception is with the SD Memory Card Failure messages. This indicates that the machine has the extended memory option but the SD portion of the processor is not operating correctly.
It will be common when updating Pre-2018 machines to new software for a 20003 No Sound Card Was Detected messaged/alarm to be generated at power up in the alarm history. New controls are equipped with audio components for use with the machine videos. The new software will check if the components are installed at power up. No service action is to be taken for this message.
Event
Title
Description
20000
Parameter Change
The control is reporting a parameter change.
20001
Initialization Event
The control is reporting an Initialization Event.
20002
Item Changed
The control is reporting an Item Changed.
20003
SD Not Enough Space
20004
Language Issue
The control is reporting a Language Notification.
20005
Offsets Changed
The control is reporting an Offsets Changed.
20006
Info Message
The control is reporting an Info Message.
20007
Spindle Fan Failure
The frequency of this message will be used for debugging purposes. Inspect the spindle fan when commanded to run.
20008
YD Recovery
This message appears in the alarm history because the control detected the WYE/DELTA contactor feedback states to be incorrect but not long enough to generate alarm 4.9973. Check all the WYE / DELTA terminal connections make sure they have a tight connection. Check the transformer taps to be in the correct location. Find out if these messages occur during heavy cuts. Do not replace any parts, if these messages continue to occur generate an error report and email it to Haas Service.
20009
CNC Power Down
The control is reporting a CNC Power Down.
20010
No Sound Card
No Sound Card was detected.
20011
Transformer Overheat
Warning: Transformer exceeded temperature limit.
20012
Electronics Overheat
Warning: Cabinet temperature reaching limit.
20013
Pallet Pool Not Run
Missing Program, Pallet missing.
20014.0
SIO Tool Changer Communication Event
Communication restored. The Tool Changer PCB on I/O PCB was detected and is communicating correctly with the main I/O PCB.
20014.1
Communication lost. The Tool Changer PCB was not detected at power on.
20015
Simulated IO Event
N/A
20016
Touchscreen Not Detected
Touchscreen not detected.
20017
Security Key Event
N/A
20018
Robot Update
Robot was updated.
20019
Tool Presetter Event
Tool Presetter was used.
20020
Specified APL Job not run
Warning: The NC program specified by the job was missing or there was a problem with the job itself.  If this was the only APL job you would get an alarm as well but if this was encountered as part of the APL scheduler the job will be skipped and the error will be noted in the APL scheduler tab.
20021
Robot Event
Robot generated a warning. More information on 20021 subcodes can be found in the HRP Troubleshooting Guide.
20022
Coolant level fell below 50%
Coolant level dropped below 50%.
20023
Coolant level restored to above 50%
Coolant level exceeded 50%.
20024
Air Pressure reached warning threshold value
Air Pressure approaching Parameter 1292 value. Triggers 10 PSI below Parameter 1292 value. Check the incoming air pressure.
20025
Air Pressure exceeded threshold value
Air Pressure exceeds Parameter 1292 value.
20026
Surge protector Event
Surge protector detected something (either faulted or repaired).
20027
Software Event
Software performed a sequence out of order.
