Pendant Memory and Setup Lock Keys
Service Home Service Alerts/News Pendant Memory and Setup Lock Keys
August 21, 2018 Pendant Memory and Setup Lock Keys
Machines built approximately after May, 2018 the memory and setup lock keys no longer use the same key.  Due to new CE regulations the Setup / Run lock has been changed and requires a different key.  This type of lock does not allow the user to leave the machine locked in Setup mode.
Memory lock key is stamped with #2341 (P/N 61-0100) (the key can be removed in either the unlock or lock position).
Setup/Run lock key is stamped with #2007 (P/N 61-0101) (the key can only be removed in the run mode position).
 Important:  If you replace the lock make sure you install the correct lock set in the correct position. If you get a call regarding the "key does not work" or "will not turn", verify that customer is using the correct key.
