UMC EC-1600 Coolant Pumps now Operate with a Variable Frequency Drive (VFD)
Service Home Service Alerts/News UMC EC-1600 Coolant Pumps now Operate with a Variable Frequency Drive (VFD)
January 24, 2020 UMC EC-1600 Coolant Pumps now Operate with a Variable Frequency Drive (VFD)
This News has been posted for more than 90 days.
Be advised that the information displayed may not be current and valid. Service News information is subject to change.
UMC's built after Nov 2019 and EC-1600's built after Jan 2020 have a variable frequency drive (VFD) [1] units.  These VFD units are located on the control cabinet above the PSUP PCB, these units will drive the coolant pump and the shower coolant pump (if equipped).
This feature allows you to select the desired pressure of the coolant pump.
An optional P-Code can now be specified along with an M08. This P-Code can be used to specify the desired pressure level of the coolant pump:
P0 = Low Pressure
P1 = Normal Pressure
P2 = High Pressure
Note: If no P-Code is specified, or the specified P-Code is out of range, then normal pressure will be used.
Note: Specifying a P2 (High Pressure), the coolant pump will operate at louder sound level, this is normal.
