User Relays and Terminal Plug Connectors on NGC I/O PCB - 34-3490B (Original Publish Date 02/27/2019)
Service Home Service Alerts/News User Relays and Terminal Plug Connectors on NGC IO PCB - 34-3490B (Original Publish Date 02/27/2019)
June 22, 2021 User Relays and Terminal Plug Connectors on NGC IO PCB - 34-3490B (Original Publish Date 02/27/2019)
This News has been posted for more than 90 days.
Be advised that the information displayed may not be current and valid. Service News information is subject to change.
7/10/2023 - Updated to Load Configuration Patch File to activate M23/M24 for machines without the Haas Robot Package.
All NGC machines are now being built with I/O PCB - 34-3490B.  This I/O PCB does not come with terminal plugs connectors [1] or user relays [2].
These plugs and relays are now sold in a kit (P/N 93-2889).
NGC Machines with I/O PCB - 34-349x
  • UMC's built approximately 06/2018 and after.
  • All other CNC built approximately 01/2019 and after.
For all NGC machines, as of 10/08/2020 the I/O PCB user outputs M23 and M24 will be mapped for the use of the Haas Robot Package.
On NGC machines without the Haas Robot package:
If the user is currently using M23 and M24 in their program, the next time configuration files are loaded from the portal, the user will not be able to control the M23 and M24 relays individually.
To activate M23/M24 for a machine without a Haas Robot Package. Login to the HBC Portal. Download the 93-2889 - NGC I/O PCB - User Relays option configuration patch file.
Note: The option file will appear on the configuration download page after the 93-2889 - NGC I/O PCB - User Relays service kit has been ordered. If the option does not appear, contact the Haas Service department.
To load the option configuration patch file to the control. Refer to the Next Generation Control - Configuration File - Download/Load procedure.
