EC-630
  1. Horizontal Mills
  2. 50-Taper
  3. EC-630
EC-630
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
630 mm Twin-Pallet HMC, 50-Taper, 40" x 37" x 40" travels
Designed for high-volume production and unattended operation for large parts and tombstones, the EC-630 offers 50-taper power and a large work envelope, with a full 4th-axis rotary system for synchronous motion, and a rear-exit chip conveyor for efficient chip management.
  • 40" x 37" x 40" (1016 x 940 x 1016 mm) travels
  • Powerful 50-taper spindle for heavy cutting
  • Standard 50+1 tool side-mount tool changer
  • Built-in pallet changer with 630 mm pallets
  • Full 4th-axis rotary system
See Available Stock
Current Lead Time
  • 50 Taper
  • 4 Axis
  • 7.5k RPM
  • 50+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
EC SERIES MACHINES
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Machine Info
    Travels S.A.E METRIC
    X Axis 40.00 in 1016 mm
    Y Axis 37.00 in 940 mm
    Z Axis 40.00 in 1016 mm
    Spindle Centerline to Pallet 1.10 in 28 mm
    Spindle S.A.E METRIC
    Max Rating 30.0 hp 22.4 kW
    Max Speed 7500 rpm 7500 rpm
    Max Torque 340.0 ft-lbf @ 700 rpm 460.0 Nm @ 700 rpm
    Drive System 2-Speed Gearbox 2-Speed Gearbox
    Taper CT or BT 50 CT or BT 50
    Bearing Lubrication Air / Oil Injection Air / Oil Injection
    Cooling Air Cooled Air Cooled
    Integrated 4th Axis (B Axis) S.A.E METRIC
    90° Rotation Time (full 4th) 3.0 s 3.0 s
    Max Weight on Platter 1500 lb 680.0 kg
    Rotational Torque (continuous) 424 ft-lbf 575 Nm
    Backlash 30 arc-sec 30 arc-sec
    Gear Ratio 106:1 106:1
    Min Resolution 0.001 ° 0.001 °
    Indexing Accuracy ± 15 arc-sec ± 15 arc-sec
    Repeatability 10 arc-sec 10 arc-sec
    Rapids on B 150 °/sec 150 °/sec
    Feedrates S.A.E METRIC
    Max Cutting 500 ipm 12.7 m/min
    Rapids on X 710 ipm 18.0 m/min
    Rapids on Y 710 ipm 18.0 m/min
    Rapids on Z 710 ipm 18.0 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 4054 lbf 18033 N
    Max Thrust Y 6985 lbf 31071 N
    Max Thrust Z 4054 lbf 18033 N
    Pallet Changer S.A.E METRIC
    Pallet Quantity 2 2
    Pallet Length 24.80 in 630 mm
    Pallet Width 24.80 in 630 mm
    Max Pallet Load 1500 lb 680.0 kg
    Max Part Diameter 39.4 in 1000 mm
    Max Part Height 39.4 in 1000 mm
    Pallet Change Time 15 s 15 s
    General S.A.E METRIC
    Coolant Capacity 95 gal 360 L
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 50+1 50+1
    Max Tool Diameter (full)** 4.0 in 102 mm
    Max Tool Diameter, Large (adjacent empty)** 7.0 in 178 mm
    Max Tool Length (from gage line) 20.00 in 508 mm
    Max Tool Weight 30.0 lb 13.6 kg
    Tool-to-Tool (avg) 4.20 s 4.20 s
    Chip-to-Chip (avg) 6.30 s 6.30 s
    Inline Air Hose 1/2 in 1/2 in
    Coupler (Air) 1/2 in 1/2 in
    Air Pressure Min 100 psi 6.9 bar
    Spindle Speed 7500 rpm 7500 rpm
    Spindle Power 30.0 hp 22.4 kW
    Domestic Pallet 240.0 in x 143.3 in x 136.0 in 610 cm x 364 cm x 345 cm
    Export Crate 241.0 in x 144.0 in x 139.0 in 612 cm x 366 cm x 353 cm
    Weight 30900 lb 12700.6 kg
    AVAILABLE OPTIONS
    VIDEOS
    RELATED PRODUCTS
    Standard Features
    • 7500-rpm Spindle
    • 50+1 Side-Mount Tool Changer, 50-Taper
    • Variable Flow Coolant
    • Belt-Type Chip Conveyor HMC
    • Enclosure Exhaust System
    • Window Air Blast
    • 95-Gallon Coolant Tank
    • Chip Tray Filter Kit
    • Single-Stage Coolant Pump
    • Control Widescreen Monitor
    • Large Remote Jog Handle with Touchscreen Display
    • Ethernet Interface
    • Power Surge Protection
    • Second Home Position
    • Advanced Tool Management
    • Media Display M-Code; M130
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    • 4th-Axis Rotary Scales
    • Phone Charging Stand
    • EC-630 Pallet Kit, Inch
    • EC-630 Pallet Kit, Metric
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    • Installation Guide
    • Layout Drawing
    • CDF Conveyor Layout Drawing
    • Torque Chart
    • Operator’s Manual
    VIDEOS
    Horizontal Mill: A Quick Overview
    Whether you need a horizontal machining center for high-volume production and unattended operation or really big work cubes and maximum weight capacity, Haas has an HMC that should fit the bill. This video gives an overview of our pallet changing mills, large-frame HMCs, and five-axis horizontal mills.
    RELATED PRODUCTS
    Smaller Work Envelope
    Haas EC-500/50
    EC-500/50
    500 mm Twin-Pallet HMC, 50-Taper, 32" x 25" x 28" travels
    • 50 Taper
    • 4 Axis
    • 7.5k RPM
        CNY ONLY
    Learn More Build & Price
    Vertical Approach
    Product Image
    VF-6/50
    CNC Vertical Mill with 64" x 32" x 30" travels
    • 50 Taper
    • 3 Axis
    • 7.5k RPM
    • 30+1 Tool Capacity
        CNY ONLY
    Larger Work Envelope
    Haas EC-1600
    EC-1600
    CNC Horizontal Mill with 64" x 50" x 32" travels
    • 50 Taper
    • 3 Axis
    • 7.5k RPM
        CNY ONLY
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    Need More Information?
