GM-1XT-5AX
  1. Vertical Mills
  2. Gantry Series
  3. GM-1XT-5AX
GM-1XT-5AX
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
5-Axis CNC Gantry Mill with 142" x 61" x 24" travels
The GM-1XT-5AX is an extended version of our 5-axis GM-1-5AX gantry mill, providing 21" (533 mm) more X-axis travel for longer parts, such as airframe components, large plates, and long extrusions. The machine’s rigid cast-iron construction provides a very stable cutting platform, and a 1" (25 mm) thick aluminum table is standard. A traveling guard protects the operator from chips and coolant, and keeps the workspace clean.
  • 24,000-rpm integral-motor spindle
  • Dual-axis spindle head: ±245 degrees of C-axis rotation and ±120 degrees of B-axis tilt
  • 62" (1575 mm) between columns for large parts
  • Rigid cast-iron construction
  • Traveling guard for chip and coolant containment
  • 1" (25 mm) thick aluminum table
See Available Stock
Current Lead Time
  • 30 Taper
  • 5 Axis
  • 24k RPM
  • 30+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Machine Info
AVAILABLE OPTIONS
DOCUMENTS
RELATED PRODUCTS
Standard Features
  • 24,000-rpm Integral Spindle, BT30
  • Variable Flow Coolant
  • Control Widescreen Monitor
  • Large Remote Jog Handle with Touchscreen Display
  • Ethernet Interface
  • CNC Control Cabinet Cooler
  • Power Surge Protection
  • Second Home Position
  • Advanced Tool Management
  • Media Display M-Code; M130
  • HaasDrop
  • Rigid Tapping
  • Phone Charging Stand
Warranty
  • 1-Year Standard Warranty
Available Options
Automation Options
  • Installation Guide
  • Layout Drawing
  • Torque Chart
  • Operator’s Manual
RELATED PRODUCTS
Shorter X Axis
Haas GM-1-5AX
GM-1-5AX
5-Axis CNC Gantry Mill with 121" x 61" x 24"
  • 30 Taper
  • 5 Axis
  • 24k RPM
    CNY ONLY
Learn More Build & Price
More Capacity
Haas GM-2-5AX
GM-2-5AX
5-Axis CNC Gantry Mill with 145" x 87.5" x 39.3" travels
  • HSK 63F Taper
  • 5 Axis
  • 20k RPM
    CNY ONLY
3-Axis Alternative
Haas GM-1
GM-1XT
3-Axis CNC Gantry Mill with 142" x 61" x 16" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
    CNY ONLY
Need More Information?
