GM-1-5AX
  1. Vertical Mills
  2. Gantry Series
  3. GM-1-5AX
GM-1-5AX
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
5-Axis CNC Gantry Mill with 121" x 61" x 24"
The GM-1-5AX is a 5-axis gantry mill designed for complex, large-part machining, such as airframe components, layup molds, and composite structures. The machine’s rigid cast-iron construction provides a very stable cutting platform, and a 1" (25 mm) thick aluminum table is standard. A traveling guard protects the operator from chips and coolant, and keeps the workspace clean.
  • 24,000-rpm integral-motor spindle
  • Dual-axis spindle head: ±245 degrees of C-axis rotation and ±120 degrees of B-axis tilt
  • 62" (1575 mm) between columns for large parts
  • Rigid cast-iron construction
  • Traveling guard for chip and coolant containment
  • 1" (25 mm) thick aluminum table
See Available Stock
Current Lead Time
  • 30 Taper
  • 5 Axis
  • 24k RPM
  • 30+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Machine Info
Travels S.A.E METRIC
X Axis 121.00 in 3073 mm
Y Axis 61.00 in 1549 mm
Z Axis 24.00 in 610 mm
Spindle Nose to Table (~ max) 18.5 in 470 mm
Spindle Nose to Table (~ min) 2.5 in 64 mm
Spindle S.A.E METRIC
Max Rating 15.0 hp 11.2 kW
Max Speed 24000 rpm 24000 rpm
Max Torque 11.0 ft-lbf @ 5500 rpm 14.9 Nm @ 5500 rpm
Drive System Integral Spindle/Motor Integral Spindle/Motor
Taper BT30 BT30
Bearing Lubrication Grease Packed Grease Packed
Cooling Liquid Cooled Liquid Cooled
B Axis - Tilt S.A.E METRIC
Travel ±120˚ ±120˚
Max Speed 105 °/sec 105 °/sec
Torque (Continuous) 112 ft-lbf 152 Nm
Brake Torque 100 ft-lbf 136 Nm
C Axis - Rotation S.A.E METRIC
Travel ± 245 ° to 245- ° 245 ° to 245- °
Max Speed 100 °/sec 100 °/sec
Torque (Continuous) 210 ft-lbf 285 Nm
Brake Torque 190 ft-lbf 258 Nm
Table S.A.E METRIC
Length 123.0 in 3124 mm
Width 53.0 in 1346 mm
Thickness 1.0 in 25 mm
Max Weight on Table (evenly distributed) 6000 lb 2722 kg
Between Columns 62.0 in 1575 mm
Feedrates S.A.E METRIC
Max Cutting 800 ipm 20.3 m/min
Rapids on X 800 ipm 20.3 m/min
Rapids on Y 2100 ipm 53.3 m/min
Rapids on Z 1100 ipm 27.9 m/min
Axis Motors S.A.E METRIC
Max Thrust X 4498 lbf 20008 N
Max Thrust Y 1645 lbf 7317 N
Max Thrust Z 2742 lbf 2197 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 30+1 30+1
Max Tool Diameter (full)** 2.5 in 64 mm
Max Tool Diameter, Large (adjacent empty)** 3.5 in 89 mm
Max Tool Length (from gage line) 11.00 in 279 mm
Max Tool Weight 12.0 lb 5.4 kg
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 24000 rpm 24000 rpm
Spindle Power 15.0 hp 11.2 kW
AVAILABLE OPTIONS
DOCUMENTS
RELATED PRODUCTS
Standard Features
  • 24,000-rpm Integral Spindle, BT30
  • Control Widescreen Monitor
  • Large Remote Jog Handle with Touchscreen Display
  • Ethernet Interface
  • Power Surge Protection
  • Second Home Position
  • Advanced Tool Management
  • Media Display M-Code; M130
  • HaasDrop
  • Rigid Tapping
  • Phone Charging Stand
Warranty
  • 1-Year Standard Warranty
Available Options
Automation Options
  • Installation Guide
  • Layout Drawing
  • Torque Chart
  • Operator’s Manual
RELATED PRODUCTS
Longer X Travel
Haas GM-1XT-5AX
GM-1XT-5AX
5-Axis CNC Gantry Mill with 142" x 61" x 24" travels
  • 30 Taper
  • 5 Axis
  • 24k RPM
    CNY ONLY
Learn More Build & Price
More Capacity
Haas GM-2-5AX
GM-2-5AX
5-Axis CNC Gantry Mill with 145" x 87.5" x 39.3" travels
  • HSK 63F Taper
  • 5 Axis
  • 20k RPM
    CNY ONLY
3-Axis Alternative
Haas GM-1
GM-1
3-Axis CNC Gantry Mill with 121" x 61" x 16" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
    CNY ONLY
Need More Information?
