GM-1
  1. Vertical Mills
  2. Gantry Series
  3. GM-1
GM-1
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
3-Axis CNC Gantry Mill with 121" x 61" x 16" travels
  • Robust 40-taper inline direct-drive spindle
  • 62" (1575 mm) between columns for large parts
  • Rigid cast-iron construction
  • Traveling guard for chip and coolant containment
  • 1" (25 mm) thick aluminum table
The GM-1 is a heavy-duty 3-axis gantry mill designed for large-part machining, such as airframe components, large plates, and long extrusions. The machine’s rigid cast-iron construction provides a very stable cutting platform, and a 1" (25 mm) thick aluminum table is standard. A traveling guard protects the operator from chips and coolant, and keeps the workspace clean.
See Available Stock
Current Lead Time
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
GM-1 SERIES
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Machine Info
    Travels S.A.E METRIC
    X Axis 121.00 in 3073 mm
    Y Axis 61.00 in 1549 mm
    Z Axis 16.00 in 406 mm
    Spindle Nose to Table (~ max) 18.5 in 470 mm
    Spindle Nose to Table (~ min) 2.5 in 64 mm
    Spindle S.A.E METRIC
    Max Rating 30.0 hp 22.4 kW
    Max Speed 8100 rpm 8100 rpm
    Max Torque 90.0 ft-lbf @ 2000 rpm 122.0 Nm @ 2000 rpm
    Taper CT or BT 40 CT or BT 40
    Bearing Lubrication Air / Oil Injection Air / Oil Injection
    Cooling Coolant Jacket Coolant Jacket
    Table S.A.E METRIC
    Length 123.0 in 3124 mm
    Width 53.0 in 1346 mm
    Thickness 1.0 in 25 mm
    Max Weight on Table (evenly distributed) 6000 lb 2722 kg
    Between Columns 62.0 in 1575 mm
    Feedrates S.A.E METRIC
    Max Cutting 800 ipm 20.3 m/min
    Rapids on X 800 ipm 20.3 m/min
    Rapids on Y 2100 ipm 53.3 m/min
    Rapids on Z 1100 ipm 27.9 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 4498 lbf 20008 N
    Max Thrust Y 1645 lbf 7317 N
    Max Thrust Z 2742 lbf 2197 N
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 30+1 30+1
    Max Tool Diameter (full)** 2.5 in 64 mm
    Max Tool Diameter, Large (adjacent empty)** 3.5 in 89 mm
    Max Tool Length (from gage line) 11.00 in 279 mm
    Max Tool Weight 12.0 lb 5.4 kg
    General S.A.E METRIC
    Coolant Capacity 95 gal 360 L
    Inline Air Hose 3/8 in 3/8 in
    Coupler (Air) 3/8 in 3/8 in
    Spindle Speed 8100 rpm 8100 rpm
    Spindle Power 30.0 hp 22.4 kW
    Export Pallet 215.0 in x 91.0 in x 98.0 in 546 cm x 231 cm x 249 cm
    Weight 16200 lb 16200 lb
    AVAILABLE OPTIONS
    DOCUMENTS
    RELATED PRODUCTS
    Standard Features
    • 8100-rpm Spindle
    • 30+1 Side-Mount Tool Changer
    • Variable Flow Coolant
    • Control Widescreen Monitor
    • Large Remote Jog Handle with Touchscreen Display
    • Ethernet Interface
    • Power Surge Protection
    • Advanced Tool Management
    • Media Display M-Code; M130
    • HaasDrop
    • Rigid Tapping
    • Internal High-Voltage Isolated Transformer
    • ECO Mode
    • Aluminum Table
    • Phone Charging Stand
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    • Installation Guide
    • Layout Drawing
    • Torque Chart
    • Operator’s Manual
    RELATED PRODUCTS
    Longer X Travel
    Haas GM-1
    GM-1XT
    3-Axis CNC Gantry Mill with 142" x 61" x 16" travels
    • 40 Taper
    • 3 Axis
    • 8.1k RPM
        CNY ONLY
    Learn More Build & Price
    More Capacity
    Haas GM-2
    GM-2
    3-Axis CNC Gantry Mill with 145" x 87.5" x 22" travels
    • 40 Taper
    • 3 Axis
    • 8.1k RPM
        CNY ONLY
    Gantry Router Alternative
    Haas GR-510
    GR-510
    CNC Gantry Router with 121" x 61" x 11" travels
    • 40 Taper
    • 3 Axis
    • 8.1k RPM
    • 10 Tool Capacity
        CNY ONLY
    Need More Information?
