Dual-Auger System w/Conveyor (DUAL AUGER-CONVEYOR)
Product Image
GET QUOTE
    CNY ONLY
Discharge chips to the left or right
  • Option Info
  • Details
OVERVIEW
DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
The Dual-Auger Chip Removal System with Conveyor removes chips from the machine quickly, with minimal coolant carryout. Dual side augers transport the chips to the front of the pan, where they are collected by a heavy-duty belt-type conveyor, and discharged at standard industrial barrel height.
The system is ideal for high-volume production applications and unattended machining operations. It can be activated via M-code or directly from the control pendant, and there are user settings to control the interval and duration of the conveyor cycle for automatic operation. The system automatically reverses if a jam occurs.
NOTE: The conveyor may be installed on the left or right side of the machine, for additional flexibility.
Fits Haas VF-1 and VF-2 series VMCs.
  • Prevents chip buildup in the enclosure
  • Ideal for a high-production environments
  • Automatic reversal upon torque overload situations
  • Activated by M-code, or manually from the control pendant
  • User settings to control cycle interval and duration for automatic operation
  • The conveyor may be installed on the right or left
Which Chip Conveyor is Right for You?
Different machining applications require different conveyor solutions. Here’s how to find the best fit for your machine and workflow.
Choose the Right Conveyor
  • CHIP REMOVAL AND COOLANT - SERVICE MANUAL
SERVICE DOCUMENTS
Get the Haas Dual Auger with Conveyor for Your New VF-2
Dual side augers transport the chips to the front of the pan, where they are collected by a heavy-duty steel, belt-type chip conveyor, and discharged at standard industrial barrel height. The system is ideal for high-production machining applications, and can be activated via M-code, or directly from the control pendant.
Reduce Your Coolant Carryout – Haas Automation Tip of the Day
In this Tip of the Day, Mark shows you how to program your chip conveyor or chip auger to keep as much coolant inside your machine as possible. With the cost of coolant these days, you can’t afford to miss this video!
Dual-Auger with Conveyor
Installs on the left or right side of the machine
Our dual-auger with conveyor option automatically removes chips from the machine, while discharging them at standard barrel height. Two side augers transport chips to the front of the pan, where they are collected by a belt-type chip conveyor and removed from the machine.
  • Installs on either side of the machine
  • Discharges chips at standard barrel height
  • Automatically reverses if a jam occurs
  • Activated via M-code, or from the control pendant
  • Settings control the interval and duration of operation
  • Automatic operation increases energy efficiency
Settings That Control Automatic Auger/Conveyor Operation
  • Setting 114 CONVEYOR CYCLE controls the interval at which the auger (multi-auger, or belt-style conveyor) will start automatic operation during a cycle.
  • Setting 115 CONVEYOR ON-TIME controls the duration the auger (multi-auger, or belt-style conveyor) will run during automatic operation.
  • Setting 196 CONVEYOR SHUTOFF specifies the amount of time to wait without activity prior to stopping the auger.
NOTE: The operator doors must be closed to operate the auger (multi-auger, or belt-style conveyor).
Program Auger/Conveyor Operation
  • M31 starts the auger (multi-auger, or belt-style conveyor) in the forward direction to remove chips.
    • Once started, and the machine is in cycle, the auger will run for the time specified in Setting 115 CONVEYOR ON-TIME, and then shut off.
    • Once started, and the machine is in cycle, the auger will restart after the time in Setting 114 CONVEYOR CYCLE, and run for the time specified in Setting 115.
    • While the machine is in cycle, you can start the auger by pressing the [CHIP FWD] button on the keyboard. Once started, Settings 114 and 115 have the same effect as described above.
    • If Setting 114 is set to zero, automatic auger operation will not occur.
  • M33 stops all automatic auger operation while in cycle.
    • Manually stop the auger while in cycle by pressing the [CHIP STOP] button on the keyboard. This stops all automatic auger operation while in cycle.
Manual Operation
  • Press the [CHIP FWD] button on the keyboard to start the auger (multi-auger, or belt-style conveyor) in the forward direction to remove chips.
  • Press the [CHIP REV] button on the keyboard to start the auger (multi-auger, or belt-style conveyor) in the reverse direction to clear a jam.
  • Press the [CHIP STOP] button on the keyboard to stop the auger (multi-auger, or belt-style conveyor).
Need More Information?
