Probe Riser Block (PRB)
Product Image
GET QUOTE
Probe Riser Block
    CNY ONLY
Raises the tool setting probe off the table
  • Overview
  • Send Info
This Option is Available with the Following Machines:
If you add a low-profile table or extended Z-axis clearance option to your Haas mill, along with the Wireless Intuitive Probing System, you may need to raise the position of your tool probe. The Probe Riser Block raises the tool probe to a position where the tools can reach it. The riser is also recommended when using tall fixtures or a rotary table on your Haas mill.
  • Recommended for use with extended Z-axis clearance options
  • Recommended for use with tall fixtures or rotary tables
Haas provides two options to raise the tool setting probe off the mill table when extended Z-axis clearance options are installed, or to avoid interference with rotary tables, workholding, or large workpieces:
• PRB-EC3: 2.5" (64 mm) probe riser block available for small- and medium-frame VMCs
• PRB-EC8: 10.5" (267 mm) probe riser block for large-frame VMCs, or when using trunnion rotary tables or tall fixtures
You can also order these risers through your local HFO service department.
MACHINE MODEL
VF-1
VF-1SSYT
VF-1YT
VF-2
VF-2SS
VF-2SSYT
VF-2YT
VF-3
VF-3SS
VF-3SSYT
VF-3YT
VF-3YT/50
VF-4
VF-4SS
VF-5/40
VF-5/40TR
VF-5/40XT
VF-5/50
VF-5/50TR
VF-5/50XT
VF-5SS
VM-2
VM-3
VMT-750
PROBE RISER
PRB-EC3
SERVICE PART #
93-1000026
MACHINE MODEL
GM-2
GM-2-5AX
VF-6/40
VF-6/40TR
VF-6/50
VF-6/50TR
VF-6SS
VF-7/40
VF-7/50
VF-8/40
VF-8/50
VF-9/40
VF-9/50
VF-10/40
VF-10/50
VF-11/40
VF-11/50
VF-12/40
VF-12/50
VF-14/40
VF-14/50
VM-6
VR-11
VR-14
VR-8
VR-9
VS-3
PROBE RISER
PRB-EC8
SERVICE PART #
93-1000025
Need More Information?
