Programmable Air, Dual-Vise (PROG AIR-DUAL VISE)
Product Image
GET QUOTE
    CNY ONLY
Operate up to two pneumatic devices directly from the Haas control
Our Dual-Vise Programmable Air option allows you to operate up to two pneumatic devices on your machine directly from the Haas control, via M-code or foot pedal. Includes adjustable regulator, pressure gauge, pressure switch, and two foot pedals.
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
The Programmable Air, Dual Vise option can control 1 or 2 air vises. There is no need to block off the secondary vise ports, if only one vise is installed. The vises are controlled individually via M code (M70 Pn/71 Pn CLAMP/UNCLAMP), with the P number defining the vise number.
NOTE: The Dual-Vise Programmable Air option is required to operate two Haas Air Vises on VF, DT, and DM series mills. Not compatible with the VF-2YT series Pallet Pool (PALLET POOL-VMC-SM). Not compatible with the Automatic Air Clamping Provision (AIR CLAMP PRO-AUTO) on Haas tilting rotary tables.
Requires a Haas mill with NGC software version 100.20.000.1200 or later.
  • M-code activated compressed air
  • Control pneumatic devices automatically
  • Programmed directly from the Haas Control
  • Mounts easily to the machine’s table
  • INSTALLATION Guide
  • Vise Options And Configurations chart
COMPATIBLE AIR VISES
