160+1 Side-Mount, HSK (SMTC-160-HSK)
Product Image
GET QUOTE
160+1 Side-Mount Tool Changer, HSK
    CNY ONLY
High-production HSK tool changer for the EC-400 and EC-500
  • 160+1 Tools
  • HSK-A63 Taper
  • Side-Mount Type
Available for order, with estimated delivery Q3 2026.
160+1 SIDE-MOUNT TOOL CHANGER
DOWNLOAD BROCHURE
HAAS JOURNAL
    • Option Info
    • Specs
    OVERVIEW
    DOCUMENTS
    AVAILABLE ON THESE MACHINES
    This Haas-designed 160+1 side-mount tool changer holds 160 tools, plus one in the spindle, providing plenty of locations for back-up tooling, or setting up tools for multiple jobs. It is the perfect choice for high-volume production, or for unattended, lights-out operation with a pallet pool, cobot, or robot.
    The tool changer features a double-arm gripper that swaps tools quickly to minimize non-cutting time, and a bi-directional servo-drive system allows direct positioning to any tool in the carousel. Faster positioning reduces cycle times during short machining operations, or when the carousel is not pre-staged for the next tool. A remote load station with automatic lockout function allows tool inspection, loading, and unloading while the machine is cutting, simplifying tool maintenance, and eliminating the need to load tools through the spindle.
    With adjacent pockets empty, the tool changer will accept oversize tooling, and there’s a built-in automatic recovery process, should a tool change be interrupted for any reason.
    • Remote load station with automatic lockout
    • Bi-directional servo-driven positioning for fast tool staging
    • Mounts to the machine’s bridge and base for stability
    • Fast tool changes reduce non-cutting time
    • Tool Table allows complete control over the tool changer
    • Identify tools as LARGE to leave adjacent pockets empty
    • Identify tools as HEAVY to slow tool changer motion
      • EC-400 Footprint Drawing
      SERVICE DOCUMENTS
      Haas EC-400
      EC-400
      400 mm Twin-Pallet HMC with 22" x 25" x 22" travels
      • 40 Taper
      • 4 Axis
      • 8.1k RPM
      • 30+1 Tool Capacity
          CNY ONLY
      Learn More Build & Price
      Haas EC-500
      EC-500
      500 mm Twin-Pallet HMC with 32" x 25" x 28" travels
      • 40 Taper
      • 4 Axis
      • 8.1k RPM
          CNY ONLY
      Tool Changer S.A.E METRIC
      Type SMTC SMTC
      Capacity 160+1 160+1
      Max Tool Diameter (full) 2.5 in 64 mm
      Max Tool Diameter (adjacent empty) 5.0 in 127 mm
      Max Tool Length (from gage line) 12.00 in 305 mm
      Max Tool Weight 12.0 lb 5.4 kg
      Need More Information?
