EC-500
  1. Horizontal Mills
  2. 40-Taper
  3. EC-500
EC-500
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
500 mm Twin-Pallet HMC with 32" x 25" x 28" travels
Designed for high-volume production and unattended operation for larger parts and tombstones, the EC-500 offers a larger work envelope and bigger pallets than the popular EC-400, while providing the same high performance and features. It features fast rapids, a full 4th-axis rotary system for synchronous motion, and a rear-exit chip conveyor for better chip management. For extended production and true “lights out” capability, a 6-station pallet pool and high-capacity tool changer are available. NOTE: An optional 50+1, 100+1, or 160+1 side-mount tool changer is highly recommended with the Pallet Pool.
  • Standard 30+1 tool side-mount tool changer,  with options for 50+1, 100+1, or 160+1
  • Built-in pallet changer with 500 mm pallets
  • Full 4th-axis rotary system
  • Available 6-station pallet pool
Note: Pallets are not interchangeable with the previous generation EC-500.
See Available Stock
Current Lead Time
  • 40 Taper
  • 4 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
160+1 SIDE-MOUNT TOOL CHANGER
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Details
    • Machine Info
    Travels S.A.E METRIC
    X Axis 32.00 in 813 mm
    Y Axis 25.00 in 635 mm
    Z Axis 28.00 in 711 mm
    Spindle Centerline to Pallet 1.10 in 28 mm
    Spindle S.A.E METRIC
    Max Rating 30.0 hp 22.4 kW
    Max Speed 8100 rpm 8100 rpm
    Max Torque 90.0 ft-lbf @ 2000 rpm 122.0 Nm @ 2000 rpm
    Taper CT40 | BT40 | HSK-A63 CT40 | BT40 | HSK-A63
    Bearing Lubrication Air / Oil Injection Air / Oil Injection
    Cooling Air Cooled Air Cooled
    Integrated 4th Axis (B Axis) S.A.E METRIC
    90° Rotation Time (full 4th) 3.0 s 3.0 s
    Max Weight on Platter 880 lb 400.0 kg
    Rotational Torque (continuous) 424 ft-lbf 575 Nm
    Backlash 30 arc-sec 30 arc-sec
    Gear Ratio 106:1 106:1
    Brake Torque 2500 ft-lbf 3390 Nm
    Min Resolution 0.001 ° 0.001 °
    Indexing Accuracy ± 15 arc-sec ± 15 arc-sec
    Repeatability 10 arc-sec 10 arc-sec
    Rapids on B 150 °/sec 150 °/sec
    Feedrates S.A.E METRIC
    Max Cutting 833 ipm 21.2 m/min
    Rapids on X 1400 ipm 35.6 m/min
    Rapids on Y 1400 ipm 35.6 m/min
    Rapids on Z 1400 ipm 35.6 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 3380 lbf 15035 N
    Max Thrust Y 2810 lbf 12500 N
    Max Thrust Z 3380 lbf 15035 N
    Pallet Changer S.A.E METRIC
    Pallet Quantity 2 2
    Pallet Length 19.69 in 500 mm
    Pallet Width 19.69 in 500 mm
    Max Pallet Load 880 lb 400.0 kg
    Max Part Diameter 29.5 in 749 mm
    Max Part Height 36.5 in 927 mm
    Pallet Change Time 15 s 15 s
    General S.A.E METRIC
    Coolant Capacity 95 gal 360 L
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 30+1 30+1
    Max Tool Diameter (full)** 2.5 in 64 mm
    Max Tool Diameter, Large (adjacent empty)** 5.0 in 127 mm
    Max Tool Length (from gage line) 12.00 in 305 mm
    Max Tool Weight 12.0 lb 5.4 kg
    Tool-to-Tool (avg) 2.80 s 2.80 s
    Chip-to-Chip (avg) 3.60 s 3.60 s
    Inline Air Hose 1/2 in 1/2 in
    Coupler (Air) 1/2 in 1/2 in
    Air Pressure Min 100 psi 6.9 bar
    Spindle Speed 8100 rpm 8100 rpm
    Spindle Power 30.0 hp 22.4 kW
    Domestic Pallet 202.0 in x 100.0 in x 111.0 in 513 cm x 254 cm x 282 cm
    Export Pallet 197.0 in x 91.5 in x 101.0 in 500 cm x 232 cm x 257 cm
    Weight 20120 lb 9126.0 kg
    Overview
    When Haas Automation set out to improve our already-popular 500 mm pallet-changing horizontal machining center, we analyzed customer feedback, and the result is a fantastic machine tool that has even the most skeptical machinists singing its praises.
    Making a Great Machine Tool Even Better
    • Available 100-Pocket Tool Changer for High-Volume Production
    • Increased Y-Axis Travel for More Capacity
    • Stepped Casting for Greater Stability
    • Rear Chip Discharge Saves Valuable Shop Floor Space
    Specification Comparison (Inch)
      NEW MODEL PREVIOUS MODEL
    Axis Travels (X, Y, Z) 32" x 25" x 28" 32" x 20" x 28"
    Maximum Optional Spindle Speed 15,000 rpm 12,000 rpm
    Tool Changer Capacity 30+1 40+1
    Optional Tool Changer Capacity 50+1, 100+1 70+1
    Rapids (X, Y, Z) 1400 in/min 1000 in/min
    Maximum Feedrate 833 in/min 500 in/min
    90° Rotation Time 3 sec 5.5 sec
    Maximum Weight on Pallet 880 lb 660 lb
    Rotational Torque (Continuous) 424 ft-lb 300 ft-lb
    Specification Comparison (Metric)
    Axis Travels (X, Y, Z) 813 x 635 x 711 mm 813 x 508 x 711 mm
    Rapids (X, Y, Z) 35.6 m/min 25.4 m/min
    Maximum Feedrate 21.2 m/min 12.7 m/min
    Maximum Weight on Pallet 400 kg 300 kg
    Rotational Torque (Continuous) 575 Nm 407 Nm
    EC-500 Chip Management
    The completely redesigned EC-500 has been improved from the ground up, with all new castings for increased rigidity and better cutting performance, 5 more inches of Y-axis travel, an available 100-pocket tool changer, and vastly improved chip evacuation.
    At the heart of the EC-500’s improved chip management system is a wider belt-type chip conveyor positioned in the center of the machine, directly under the spindle. The steep walls of the interior enclosure easily funnel chips to the conveyor.
    The conveyor discharges chips at the height of a full-size industrial barrel. Washdown nozzles mounted in the ceiling are fed by a separate coolant pump, and allow you to direct coolant flow to areas where chips may gather, to further enhance chip evacuation.
    EC-500 Coolant Ring
    The 4-nozzle coolant ring surrounding the spindle nose is perfectly positioned so that nozzles can be pointed at the shortest tools, and others can be positioned for longer tools. The compact, cylindrical design prevents chips from collecting on top. NOTE: The Haas Programmable Coolant Nozzle (P-COOL) is not available on the EC-500.
    EC-500 Cycloidal Rotary Drive
    The cycloidal rotary drive system – designed for machine tools and robotics – provides a great combination of speed, accuracy, and durability to the B axis. The rugged design provides long service life, with little or no maintenance, and is especially durable in a crash. The cycloidal rotary drive can be back driven to absorb energy from an impact. The shock-load capacity is 5 times the rated torque of the gearbox, and the entire gearbox is a simple drop-in replacement, should damage occur.
    EC-500 Hydraulic Pallet-Clamping System
    The hydraulic power unit provides power to clamp the pallets to the pallet receiver, as well as raise and lower the pallet-changer mechanism.
    EC-500 Increased Axis Travels
    An extra 5" (127 mm) of Y-axis travel can make all the difference in the world. Now, the spindle centerline can get 26.1" (663 mm) above the surface of the pallet.
    EC-500 Stepped Base and Column
    The stepped base and column design of the EC-500, where one X-axis linear guide rail is on a different horizontal plane than the other, increases the rigidity and stability of the spindle-head column assembly. With hydraulic pallet clamping and the stepped base/column design, the EC-500 is more rigid than ever, all the way to the top!
    EC-500 Automatic Probe Riser
    An automatic probe arm stores the tool setting probe in a protective compartment during machining operations. When the tool probe is needed, an M104 code activates the automatic probe arm to lift the probe and lock it into place. When probing is complete, an M105 retracts the probe to its protective compartment.
    AVAILABLE OPTIONS
    VIDEOS
    CUSTOMER TESTIMONIALS
    RELATED PRODUCTS
    Standard Features
    • 8100-rpm Spindle
    • 30+1 Side-Mount Tool Changer
    • Variable Flow Coolant
    • Belt-Type Chip Conveyor HMC
    • Window Air Blast
    • 95-Gallon Coolant Tank
    • Chip Tray Filter Kit
    • Single-Stage Coolant Pump
    • Control Widescreen Monitor
    • Ethernet Interface
    • CNC Control Cabinet Cooler
    • Power Surge Protection
    • Second Home Position
    • Advanced Tool Management
    • Media Display M-Code; M130
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    • 4th-Axis Rotary Scales
    • Stainless Steel Way Covers
    • Phone Charging Stand
    • EC-500 Pallet Kit, Inch
    • EC-500 Pallet Kit, Metric
    Shipping
    • Lifting Provision
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
      • Installation Guide
      • Layout Drawing
      • CDF Conveyor Layout Drawing
      • Torque Chart
      • Operator’s Manual
      • EC Series Flyer
      VIDEOS
      Horizontal Mill: A Quick Overview
      Whether you need a horizontal machining center for high-volume production and unattended operation or really big work cubes and maximum weight capacity, Haas has an HMC that should fit the bill. This video gives an overview of our pallet changing mills, large-frame HMCs, and five-axis horizontal mills.
      TMF Center
      "TMF Center performs a lot of large cuts. The 50-taper rigidity is what made our Haas machines helpful in our shop. We were thrilled when Haas came out with the EC-500. It's very smooth when cutting, quiet, it has lot of options, and the twin pallet is an awesome feature. The EC-500 lets us stay productive, while its changing out parts we’ve got the other pallet still producing. Our Haas machines have helped us grow our sales from 5 million in sales to over 50 million in sales."
      – Lori Van Meter, President
      RELATED PRODUCTS
      SMALLER WORK ENVELOPE
      Haas EC-400
      EC-400
      400 mm Twin-Pallet HMC with 22" x 25" x 22" travels
      • 40 Taper
      • 4 Axis
      • 8.1k RPM
          CNY ONLY
      Learn More Build & Price
      DIFFERENT APPROACH
      Haas UMC-750
      UMC-750
      5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
      • 40 Taper
      • 5 Axis
      • 8.1k RPM
          CNY ONLY
      50-TAPER POWER
      Haas EC-1600
      EC-1600
      CNC Horizontal Mill with 64" x 50" x 32" travels
      • 50 Taper
      • 3 Axis
      • 7.5k RPM
      • 50+1 Tool Capacity
          CNY ONLY
      Build & Price
      Get Started
      Need More Information?
      NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
      *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
      Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
      **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
      ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
      † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
