EC-400
  1. Horizontal Mills
  2. 40-Taper
  3. EC-400
EC-400
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
400 mm Twin-Pallet HMC with 22" x 25" x 22" travels
Designed for high-volume production and unattended operation, the all-new EC-400 is faster, more compact, more rigid, and more capable than ever before. It features a larger work envelope, faster rapids, a full 4th-axis rotary system for synchronous motion, and much better chip management. For extended production and true “lights out” capability, a 6-station pallet pool and high-capacity tool changer are available. NOTE: An optional 50+1, 100+1, or 160+1 side-mount tool changer is highly recommended with the Pallet Pool.
  • Standard 30+1 tool side-mount tool changer,  with options for 50+1, 100+1, or 160+1
  • Built-in pallet changer with 400 mm pallets
  • Full 4th-axis rotary system
  • Available 6-station pallet pool
Note: Pallets are not interchangeable with the previous generation EC-400.
See Available Stock
Current Lead Time
  • 40 Taper
  • 4 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
160+1 SIDE-MOUNT TOOL CHANGER
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Automation
    • Details
    • Machine Info
    Travels S.A.E METRIC
    X Axis 22.00 in 559 mm
    Y Axis 25.00 in 635 mm
    Z Axis 22.00 in 559 mm
    Spindle S.A.E METRIC
    Max Rating 30.0 hp 22.4 kW
    Max Speed 8100 rpm 8100 rpm
    Max Torque 90.0 ft-lbf @ 2000 rpm 122.0 Nm @ 2000 rpm
    Taper CT40 | BT40 | HSK-A63 CT40 | BT40 | HSK-A63
    Bearing Lubrication Air / Oil Injection Air / Oil Injection
    Cooling Air Cooled Air Cooled
    Integrated 4th Axis (B Axis) S.A.E METRIC
    90° Rotation Time (full 4th) 3.0 s 3.0 s
    Max Weight on Platter 880 lb 400.0 kg
    Rotational Torque (continuous) 424 ft-lbf 575 Nm
    Backlash 30 arc-sec 30 arc-sec
    Gear Ratio 106:1 106:1
    Brake Torque 2500 ft-lbf 3390 Nm
    Min Resolution 0.001 ° 0.001 °
    Indexing Accuracy ± 15 arc-sec ± 15 arc-sec
    Repeatability 10 arc-sec 10 arc-sec
    Rapids on B 150 °/sec 150 °/sec
    Feedrates S.A.E METRIC
    Max Cutting 833 ipm 21.2 m/min
    Rapids on X 1400 ipm 35.6 m/min
    Rapids on Y 1400 ipm 35.6 m/min
    Rapids on Z 1400 ipm 35.6 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 3380 lbf 15035 N
    Max Thrust Y 2810 lbf 12500 N
    Max Thrust Z 3380 lbf 15035 N
    Pallet Changer S.A.E METRIC
    Pallet Quantity 2 2
    Pallet Length 15.75 in 400 mm
    Pallet Width 15.75 in 400 mm
    Max Pallet Load 880 lb 400.0 kg
    Max Pallet Load (w/Pallet Pool) 500 lb 227 kg
    Pallet Change Time 15 s 15 s
    General S.A.E METRIC
    Coolant Capacity 95 gal 360 L
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 30+1 30+1
    Max Tool Diameter (full)** 2.5 in 64 mm
    Max Tool Diameter, Large (adjacent empty)** 5.0 in 127 mm
    Max Tool Length (from gage line) 12.00 in 305 mm
    Max Tool Weight 12.0 lb 5.4 kg
    Tool-to-Tool (avg) 2.80 s 2.80 s
    Chip-to-Chip (avg) 3.60 s 3.60 s
    Inline Air Hose 1/2 in 1/2 in
    Coupler (Air) 1/2 in 1/2 in
    Air Pressure Min 100 psi 6.9 bar
    Spindle Speed 8100 rpm 8100 rpm
    Spindle Power 30.0 hp 22.4 kW
    Domestic Pallet 202.0 in x 100.0 in x 112.0 in 513 cm x 254 cm x 284 cm
    Export Crate 176.0 in x 92.0 in x 101.0 in 447 cm x 234 cm x 257 cm
    Weight 17520 lb 7947.0 kg
    Available 6+1 Pallet Pool
    Whether you’re doing high-volume production runs, high-mix/low volume machining, or just want to run lights-out, you can boost the productivity of your EC-400 with our fully integrated 6+1 pallet pool. NOTE: The Pallet Pool requires the optional 50+1 or 100+1 side-mount tool changer.
    Learn More
    Overview
    When Haas Automation set out to improve our already-popular 400 mm pallet-changing horizontal machining center, we analyzed customer feedback, and the result is a fantastic machine tool that has even the most skeptical machinists singing its praises.
    Making a Great Machine Tool Even Better
    • Available 100-Pocket Tool Changer for High-Volume Production
    • Increased Y-Axis Travel for More Capacity
    • Stepped Casting for Greater Stability
    • Rear Chip Discharge Saves Valuable Shop Floor Space
    Specification Comparison (Inch)
      NEW MODEL PREVIOUS MODEL
    Axis Travels (X, Y, Z) 22" x 25" x 22" 20" x 20" x 20"
    Maximum Optional Spindle Speed 15,000 rpm 12,000 rpm
    Tool Changer Capacity 30+1 24+1
    Optional Tool Changer Capacity 50+1, 100+1 40+1, 70+1
    Rapids (X, Y, Z) 1400 in/min 1000 in/min
    Maximum Feedrate 833 in/min 500 in/min
    90° Rotation Time 3 sec 5.5 sec
    Maximum Weight on Pallet 880 lb 660 lb
    Rotational Torque (Continuous) 424 ft-lb 300 ft-lb
    Specification Comparison (Metric)
    Axis Travels (X, Y, Z) 559 x 635 x 559 mm 508 x 508 x 508 mm
    Rapids (X, Y, Z) 35.6 m/min 25.4 m/min
    Maximum Feedrate 21.2 m/min 12.7 m/min
    Maximum Weight on Pallet 400 kg 300 kg
    Rotational Torque (Continuous) 575 Nm 407 Nm
    EC-400 Chip Management
    The completely redesigned EC-400 has been improved from the ground up, with all new castings for increased rigidity and better cutting performance, 5 more inches of Y-axis travel, an available 100-pocket tool changer, and vastly improved chip evacuation.
    At the heart of the EC-400’s improved chip management system is a wider belt-type chip conveyor positioned in the center of the machine, directly under the spindle. The steep walls of the interior enclosure easily funnel chips to the conveyor.
    The conveyor discharges chips at the height of a full-size industrial barrel. Washdown nozzles mounted in the ceiling are fed by a separate coolant pump, and allow you to direct coolant flow to areas where chips may gather, to further enhance chip evacuation.
    EC-400 Coolant Ring
    The 4-nozzle coolant ring surrounding the spindle nose is perfectly positioned so that nozzles can be pointed at the shortest tools, and others can be positioned for longer tools. The compact, cylindrical design prevents chips from collecting on top. NOTE: The Haas Programmable Coolant Nozzle (P-COOL) is not available on the EC-400.
    EC-400 Pallet Schedule Table
    In previous Haas pallet-changing machines, the G188 code was used to call a part program from the Pallet Schedule Table (PST), based on which pallet was loaded. Continuous operation was achieved by running a main program that consisted of an M50 to perform a pallet change, the G188 to call the program for the loaded pallet, and an M99 to loop the whole process. The M50 loaded the next scheduled pallet, and the G188 called the program designated for that pallet.
    With the G188, however, if you restarted your machining process in the middle of one of the pallet programs, it didn’t allow you to get back to the main program to continue uninterrupted machining. You had to wait for your restarted program to finish, select your main program again, and then start your continuous cycle.
    We developed a new M-code to solve this problem. The M199 is used at the end of a program. When the program is started by pressing [CYCLE START] in Memory mode, the M199 acts exactly like an M30 (Program End and Reset). But if the program is started by pressing [INSERT] while the Pallet Schedule Table is displayed, the M199 will command a pallet change to load the next scheduled pallet, and then run the program associated with that pallet. This allows the user to start machining on any pallet, and continue uninterrupted machining, as long as pallets are scheduled.
    EC-400 Cycloidal Rotary Drive
    The cycloidal rotary drive system – designed for machine tools and robotics – provides a great combination of speed, accuracy, and durability to the B axis. The rugged design provides long service life, with little or no maintenance, and is especially durable in a crash. The cycloidal rotary drive can be back driven to absorb energy from an impact. The shock-load capacity is 5 times the rated torque of the gearbox, and the entire gearbox is a simple drop-in replacement, should damage occur.
    EC-400 Hydraulic Pallet-Clamping System
    The hydraulic power unit provides power to clamp the pallets to the pallet receiver, as well as raise and lower the pallet-changer mechanism.
    EC-400 Increased Axis Travels
    An extra 5" (127 mm) of Y-axis travel can make all the difference in the world. Now, the spindle centerline can get 27.13" (689 mm) above the surface of the pallet. We also increased the X- and Z-axis travels by 2" (51 mm) each.
    EC-400 Stepped Base and Column
    The stepped base and column design of the EC-400, where one X-axis linear guide rail is on a different horizontal plane than the other, increases the rigidity and stability of the spindle-head column assembly. With hydraulic pallet clamping and the stepped base/column design, the EC-400 is more rigid than ever, all the way to the top!
    EC-400 Automatic Probe Riser
    An automatic probe arm stores the tool setting probe in a protective compartment during machining operations. When the tool probe is needed, an M104 code activates the automatic probe arm to lift the probe and lock it into place. When probing is complete, an M105 retracts the probe to its protective compartment.
    AVAILABLE OPTIONS
    VIDEOS
    CUSTOMER TESTIMONIALS
    RELATED PRODUCTS
    Standard Features
    • 8100-rpm Spindle
    • 30+1 Side-Mount Tool Changer
    • Variable Flow Coolant
    • Belt-Type Chip Conveyor HMC
    • Window Air Blast
    • 95-Gallon Coolant Tank
    • Chip Tray Filter Kit
    • Single-Stage Coolant Pump
    • Control Widescreen Monitor
    • Ethernet Interface
    • CNC Control Cabinet Cooler
    • Power Surge Protection
    • Second Home Position
    • Advanced Tool Management
    • Media Display M-Code; M130
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    • 4th-Axis Rotary Scales
    • Stainless Steel Way Covers
    • Phone Charging Stand
    • EC-400 Pallet Kit, Inch
    • EC-400 Pallet Kit, Metric
    Shipping
    • Lifting Provision
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    • 3D Model | SMTC-160 (ZIP)
    • 3D Model | Pallet Pool (ZIP)
    • 3D Model | Pallet Pool | SMTC-160 (ZIP)
    • Installation Guide
    • Layout Drawing
    • CDF Conveyor Layout Drawing
    • SMTC-160 Footprint Drawing
    • Torque Chart
    • Operator’s Manual
    • EC-400 Series Flyer
    • Automation Options And Configurations chart
    VIDEOS
    EC-400
    The completely redesigned EC-400 has been improved from the ground up, with all new castings for increased rigidity and better cutting performance, 5 more inches of Y-axis travel, vastly improved chip evacuation, and an available 100-pocket tool changer. See how Haas engineers have taken our latest HMC to the next level.
    Horizontal Mill: A Quick Overview
    Whether you need a horizontal machining center for high-volume production and unattended operation or really big work cubes and maximum weight capacity, Haas has an HMC that should fit the bill. This video gives an overview of our pallet changing mills, large-frame HMCs, and five-axis horizontal mills.
    Lyntech Engineering, Inc.
    “The tool-life management on our Haas EC-400s is second to none. It has helped us increase our production, by implementing preventive/predictive tool changing, based on the feedback from the tool management system. The other thing is the probing. We have some very critical dimensions on our parts, and we’re able to use in-process probing between operations to prevent any variations in the parts.”
    Jason Hudkins, President of Lyntech Engineering
    Phillips Precision
    “We are primarily a job shop, but we also have our own product line, which makes us somewhat special. We had a customer that had a high demand for parts, so we purchased an EC-400. I saw the 6+1 Pallet Pool that was available, and it was a no brainer. The machine ran non-stop, with no hiccups. We had all 7 pallets loaded up at night when our workers would go home for the day, and it would run all night. Our Pallet Pool got us ahead of schedule, and let us take on more work. Our EC-400 has probably saved about 25% on our runtime. We have 15,000-rpm, faster feeds and speeds, much faster tool changes, finishes are great, accuracy is very good, and repeatability is no problem.”
    – Steve Phillips, President
    Customer Spotlight - K&M Engineering, Inc.
    K&M Engineering was founded by Jason Kittredge and Michael Marrazzo in 2013, with a Haas VF-2 and Mini Mill (in a garage). In 2020, K&M Engineering invested in their first twin-pallet horizontal machining center, a Haas EC-400, to compliment their growing fleet of Haas verticals. The 4-axis capabilities of the EC-400 have allowed them to simplify and eliminate difficult setups, while holding consistent tight tolerances, run after run.
    RELATED PRODUCTS
    VERTICAL SPINDLE
    Haas VF-3SSYT
    VF-3SSYT
    Super-Speed CNC Vertical Mill with 40" x 26" x 25" travels
    • 40 Taper
    • 3 Axis
    • 12k RPM
        CNY ONLY
    Learn More Build & Price
    DIFFERENT APPROACH
    Haas UMC-750
    UMC-750
    5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
    • 40 Taper
    • 5 Axis
    • 8.1k RPM
        CNY ONLY
    50-TAPER POWER
    Haas EC-1600
    EC-1600
    CNC Horizontal Mill with 64" x 50" x 32" travels
    • 50 Taper
    • 3 Axis
    • 7.5k RPM
    • 50+1 Tool Capacity
        CNY ONLY
    Build & Price
    Get Started
    Need More Information?
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
