G-code, M-code, and Setting
Service Home G70 Finishing Cycle (Group 00)
The G70 Finishing Cycle can be used to finish cut paths that are rough cut with stock removal cycles such as G71, G72 and G73.
P - Starting Block number of routine to execute
Q - Ending Block number of routine to execute
G18 Z-X plane must be active
NOTE
The P values are modal. This means if you are in the middle of a canned cycle and a G04 Pnn or an M97 Pnn is used the P value will be used for the dwell / subprogram as well as the canned cycle.
G70 Finishing Cycle: [P] Starting block, [Q] Ending Block.
G71 P10 Q50 F.012 (rough out N10 to N50 the path) ;
N10 ;
F0.014 ;
N50 ;
G70 P10 Q50 (finish path defined by N10 to N50) ;
The G70 cycle is similar to a local subprogram call. However, the G70 requires that a beginning block number (P code) and an ending block number (Q code) be specified.
The G70 cycle is usually used after a G71, G72 or G73 has been performed using the blocks specified by P and Q. Any F, S, or T codes with the PQ block are effective. After execution of the Q block, a rapid (G00) is executed returning the machine to the start position that was saved before the starting of the G70. The program then returns to the block following the G70 call. A subprogram in the PQ sequence is acceptable providing that the subprogram does not contain a block with an N code matching the Q specified by the G70 call. This feature is not compatible with FANUC controls.
After a G70, the block following the G70 will be executed, not the block with an N code matching the Q code specified by the G70 call.
