G-code, M-code, and Setting
Service Home G92 Set Work Coordinate Systems Shift Value (Group 00)
This G-code does not move any of the axes; it only changes the values stored as user work offsets. G92 works differently depending on Setting 33, which selects a FANUC or HAAS coordinate system.
FANUC or HAAS
If Setting 33 is set to FANUC or HAAS, a G92 command shifts all work coordinate systems (G54-G59, G110-G129) so that the commanded position becomes the current position in the active work system. G92 is non-modal.
A G92 command cancels any G52 in effect for the commanded axes. Example: G92X1.4 cancels the G52 for the X-Axis. The other axes are not affected.
The G92 shift value is displayed at the bottom of the Work Offsets page and may be cleared there if necessary. It is also cleared automatically after power-up, and any time [ZERO RETURN] and [ALL] or [ZERO RETURN] and [SINGLE] are used.
G92 Clear Shift Value From Within a Program
G92 shifts may be canceled by programming another G92 shift to change the current work offset back to the original value.
O60921 (G92 SHIFT WORK OFFSETS) ;
(G54 X0 Y0 Z0 is at the center of mill travel) ;
G00 G90 G54 X0 Y0 (Rapid to G54 origin) ;
G92 X2. Y2. (Shifts current G54) ;
G92 X-2. Y-2. (Shifts current G54 back to original) ;
M30 (End program) ;
