3 - HMS - Installation
HMS - Operator's / Service Manual
  • 0 - HMS - Table of Contents
  • 1 - HMS - Introduction
  • 2 - HMS - Safety
  • 3 - HMS - Installation
  • 4 - HMS - Operation
  • 5 - HMS - Maintenance
  • 3.1 HMS Installation
HMS-3123 - Installation
Revision C - 05/2026
This chapter will walk through the general process needed to install the HAAS Miter Bandsaw - 3123. This includes unpacking, leveling, and powering up.
Tools required:
  • 18mm sockets
  • Machinist's Level
Note: The machine will come with all of its accessories and spare sparts in four cardboard boxes.
Note: Machine weight is 2203 lbs (1800 kg).
HMS - Unpacking
Updated
 Remove the wrap around the machine.
Using an 18mm socket, remove the four mounting bolts that hold the machine to the skid. Two in the front [1] and two in the rear [2].
Use a forklift to carefully remove the bandsaw from the skid. Position the forks to lift the machine from its side, following the arrow shown in the image.
The bandsaw will require 4 leveling feet in order to place the machine safely to the ground.
Note: The required feet can be found in one of the four cardboard boxes provided with the machine.
Locate the 4 mounting points to install the feet.
Note: There are two mounting points at the front [1] and two at the rear.
Install the machine's leveling feet while the bandsaw is still lifted from the ground.
Once the feet have been installed, carefully lower the machine to the ground.
HMS - Leveling
Position a level on the machined surface of the table as shown in the image.
Use the leveling feet located at the bottom of the bandsaw to adjust and level the machine from front to back.
Use the leveling feet located at the bottom of the bandsaw to adjust and level the machine from side to side.
HMS - Oil Refill
Updated
Note:  The HMS will not arrive filled with oil.
Before filling the machine with oil, turn OFF the band saw.
Remove the access panel on the side of the machine by unscrewing the 4 fasteners [2] , open the cap to the hydraulic reservoir [3].
Use either ISO 46 or ISO 32 oil, and fill the machine to 6.5 - 7.0 gallons of oil or until indicated full.
Note: Do not cross-contaminate oils during a refill.
HMS - Extended Bed Installation
Remove the packaging of the extended bed.
Install the feet of the extended bed to the table's legs. [1]
Locate the 4 mounting points to install the legs of the extended bed [2].
Updated
Position the extended bed against the side walls of the band saw.
Fasten the extended bed to the band saw using the pre-tapped holes located on the machine’s side.
After installation, use a bubble level to perform a preliminary leveling of the extended bed.
Note: Run a test pass. Take a piece of bar stock and smoothly slide it across the extended bed toward the blade in a single, continuous motion.
Updated
On the casting, locate the internal threads [1] as shown in the image. Next, move the extended bed, connecting the mounting plate [2] to the casting surface.
To ensure the mounting plate holes align with the threads, adjust the leveling feet on the extended bed to bring it to the correct height and orientation.
Fasten the extended bed using the provided hardware.
HMS - Electrical Installation
DANGER: WORKING WITH ELECTRICAL SERVICES REQUIRED FOR A BANDSAW IS EXTREMELY HAZARDOUS. ALL POWER TO THE SAW MUST BE TURNED OFF, LOCKOUT-TAGOUT AT THE SOURCE PRIOR TO CONNECTING THE LINE WIRES TO THE SAW. HOWEVER, IF THIS NOT THE CASE OR ARE NOT SURE HOW TO DO THIS, CHECK WITH APPROPRIATE PERSONNEL OR OBTAIN THE NECESSARY HELP BEFORE CONTINUING. ALWAYS CHECK THE INCOMING LINES WITH AN AC VOLTAGE DETECTOR TO MAKE SURE POWER HAS BEEN DISCONNECTED.
The miter band saw will arrive with the pigtail shown in the image.
Source a compatible adapter and connect the machine's pigtail to the adapter.
Important: Ensure that the electrical drop meets the machine's power specification.
Once the connection is secure and verified, proceed to powering on the band saw.
Verify that the machine is phased correctly by turning on the hydraulic pump.
Check the hydraulic pressure gauge [1] on the saw to confirm the phasing is correct.
Important: If the gauge shows no pressure while the pump is running, turn off the saw, disconnect it from the main power supply, and swap the R and T lead positions only.
