5 - HMS - Maintenance
HMS - Operator's / Service Manual
  • 0 - HMS - Table of Contents
  • 1 - HMS - Introduction
  • 2 - HMS - Safety
  • 3 - HMS - Installation
  • 4 - HMS - Operation
  • 5 - HMS - Maintenance
  • 5.1 HMS Maintenance
  • 5.2 HMS Service Parts List
5.1 HMS Maintenance
HMS-3123 - Maintenance
Revision A - 9/2025
Regular maintenance is essential for the Haas Miter Saw.  This page provides the recommended maintenance intervals along with the corresponding instructions.
HMS - Oil Reservoir
Note:  The HMS will not arrive with ISO 46 oil already inside the machine.
In the case of a refill, turn OFF the band saw.
Remove the panel on the side of the machine [1], open the cap to the hydraulic reservoir [2] and fill the machine with either ISO 46 or ISO 32 oil.
Note: Do not cross-contaminate oils during a refill.
In the case of an oil change, turn OFF the band saw.
To remove the fluid from the reservoir, begin by taking off the side panel of the machine at location [1].
Remove the rubber grommet found at position [2]. Once the opening is accessible, insert a multi-purpose transfer pump and use it to siphon the fluid from the internal reservoir into an external container.
HMS - Coolant Refill
Locate the coolant reservoir on the back end of the machine as shown in the image.
Inspect the coolant reservoir and verify that it is free of chips or debris.
Fill the reservoir with coolant until the fluid level is just below the top of the metal mesh [1].
Note: Overfilling beyond the mesh may allow chips to be drawn into the system when the pump is operating.
HMS-3123 - Service Parts List
Revision A - 12/2025
Service Parts List
Part Number DESCRIPTION
93-5605 E-STOP BUTTON HMS-3123
93-5527 VFD HMS-3123
93-5673 SQUARE RELAY HMS-3123
93-5471 TRANSFORMER HMS-3123
93-5674 THERMAL RELAY HMS-3123
93-5675 AC CONTACTOR HMS-3123
93-5676 AUXILARY CONTACTOR HMS-3123
93-5677 GREEN PUSH BUTTON HMS-3123
93-5706 LIMIT SWITCH HMS-3123
93-5678 LIMIT SWITCH HMS-3123
93-5469 DOOR INTERLOCK SWITCH HMS-3123
93-5683 LUBE TANK HMS-3123 HVS-1
93-5694 CTRL SCREEN HMS-3123
93-5695 CTRL DIAL HMS-3123
93-5696 CTRL CABINET HINGE HMS-3123
93-5697 SAW BLADE DOOR HINGE HMS-3123
93-5679 BLACK LEVERS HMS-3123
93-5703 SAW BLADE MOTOR HMS-3123
93-5699 SAW BLADE GEAR REDUCER HMS-3123
93-5702 HYD PUMP HMS-3123
93-5680 HYD PUMP WHEEL HMS-3123
93-5681 HEAD HEIGHT HYD CYLINDER HMS-3123
93-5682 WIRE BRUSH HMS-3123
93-5505 BLADE TENSION DEVICE HMS-3123
93-5561 TABLE EXTENDER HMS-3123
93-5560 OUTFEED TABLE HMS-3123
93-5528 INFEED TABLE HMS-3123
93-5468 COOLANT PUMP HMS-3123
93-5467 HMS3123 FLUID LEVEL INDICATOR
