4 - HSF-450 - Maintenance
HSF-450 - Operator's/Service Manual
  • 1 - HSF-450 - Introduction
  • 2 - HSF-450 - Installation
  • 3 - HSF-450 - Operation
  • 4 - HSF-450 - Maintenance
  • 5 - HSF-450 - Troubleshooting
  • 4.1 Maintenance
4.1 Maintenance
Regular cleaning
  • Turn off the power, unplug the unit, and clean the machine's surface with a soft and damp cloth. Do not allow cleaning liquid inside of the machine. Abrasive methods of cleaning are not recommended.
  • If necessary, clean the inner surface of the heater. The evaporation of residual cutting fluid or other vapors may contaminate the heater. Using clean and dry shrink fit holders will significantly reduce contamination.
  • The water tank needs to be cleaned thoroughly every six months. To clean, disconnect the water pump connection line, remove the cooling water pipe, pull out the water tank, and clean out the debris on the bottom. Refill with the proper quantity and ratio of coolant.
Enable/Disable the Tool Coolant Water Pump
Perform the following to enable or disable the tool coolant Water Pump when performing maintenance on the machine.
Enable Water Pump:
  • Turn the air switch valve clockwise until open.
  • Pull out the emergency stop.
  • Press the water pump switch.
Disable Water Pump:
  • Press the water pump button.
  • Press the emergency stop.
  • Turn the air switch valve counter-clockwise until closed.
Inspection
  • Check the cooling water tank weekly to ensure that the water level is not lower than 1/2 of the water tank capacity. Add coolant as necessary.
  • Check the air pressure gauge; the air pressure must be between 75 to 87 PSI (0.5 to 0.6 MPA).
Other
Warning: Do not maintain or repair any portion of the HSF-450 within 5 minutes of turning it off, as there may still be residual current.
  1. Do not adjust any components on the internal circuit board.
  2. Do not open the electrical cabinet during use.
  3. Do not clean the inside of the electrical cabinet with a wet cloth or water.
