8 - HDC-3-5AX - Maintenance
HDC-3-5AX Operator's/Service Manual
  • 0 - HDC-3-5AX - Table of Contents
  • 1 - HDC-3-5AX - Introduction
  • 2 - HDC-3-5AX - Legal Information
  • 3 - HDC-3-5AX - Safety
  • 4 - HDC-3-5AX - Installation
  • 5 - HDC-3-5AX - Control Icons
  • 6 - HDC-3-5AX - Operation
  • 7 - HDC-3-5AX - MRZP
  • 8 - HDC-3-5AX - Maintenance
  • 9 - HDC-3-5AX - Geometry and Alignment
  • HDC-3-5AX Maintenance Schedule
  • HDC-3-5AX - Spindle Chiller Maintenance
  • HDC-3-5AX - Service Parts List
  • VS/HDC Way Cover Wiper - Replacement
8.1 HDC-3-5AX Maintenance Schedule
HDC-3-5AX Tool Changer
Maintenance Item Interval
Clean the chips from the tool changer.
Weekly
Inspect motors and mechanical sensors.
Monthly
Inspect motors and proximity sensors.
Monthly
Grease the guide rails.
Monthly
Grease the extractor fingers.
Monthly
Replace the filter bag.
Check the Gauge
Inspect the hoses for cracking.
Six Months
Clean vector drive air vents / filter.
Monthly
Inspect windows for damage.
Daily
Inspect the door interlock operation.
Daily
Inspect waycovers and lubricate.
Monthly
Pneumatics
Inspect the spindle air regulator pressure.
Weekly
Six Months
Clean the Air Purge Solenoid.
Annually
Probe System
Check the probe batteries.
Six Months
Check probe calibration.
Six Months
Standard Coolant System
Clean the filter screen.
As Required
Inspect the coolant level.
Weekly
Inspect the coolant concentration. Fill out the Mixture - Maintenance Log sheet.
Weekly
Completely clean the coolant tank and replace the coolant.
Six Months
Clean the standard coolant filter.
Six Months
Verify coolant refill is operating correctly.
Six Months
Through Spindle Coolant (TSC) 300/1K PSI
Clean the TSC-300 / 1K Pump Filter.
Six Months
Six Months
Verify the Auto Clean system is operating correctly.
Six Months
Spindle
Spindle Warm-up. Daily
Clean and lubricate the spindle taper.
Monthly
Spindle drawbar force measurement.
Six Months
Spindle Chiller
Inspect/Clean Air filter Weekly
Check fluid tank level Weekly
Fill fluid tank As Required
Remove dust and decontamination from unit Weekly
Replace the chiller fluid Annualy
Inspect/Clean fluid tank When fluid is changed
Inspect/Clean condenser Annualy
Clean inside and outside of unit Annualy
8.2 HDC-3-5AX - Spindle Chiller Maintenance
This section provides details about the maintenance required for the HDC-3-5AX spindle chiller.
Before performing maintenance on the chiller. The equipment must be shut down first. Turn off the machine and wait for the chiller to be shut down for 5 minutes. Otherwise there will be a risk of electric shock.
When the ambient temperature is below 0°C and the shutdown is long, the internal water must be drained.
Spindle Chiller
HDC-3-5AX Spindle Chiller Maintenance
This image shows the key components of the Spindle Chiller:
Front of Chiller:
  1. Chiller Fluid Inlet
  2. Chiller Fuild Outlet
  3. Access Panel
  4. Display/Control Keypad
  5. Air Filter
  6. Chiller Fluid Tank Filler
  7. Chiller Fluid Level Gauge
  8. Drain Plug
Back of Chiller:
         9. Pressure Gauge
         10. Drain Value
Inspect the fluid tank level by looking at the fluid level gauge located on the front of the spindle chiller [7]. To add fluid to the tank, remove the cap to the inlet at the top of the unit, and fill the tank with a Mobil Velocite Oil No 3 (PN: 93-4894) until the gauge reads the level is at the top of the NORMAL or at the FULL level. The tank capacity is approximately 25 liters.
To clean the air inlet filter, remove the grate to gain access to the filter unit. From there, remove the filter screen so that any dust or debris can be picked out of the filter. If necessary, wash the filter using water to get rid of contaminants.
Make sure that the air outlets are clear of dust and debris. It is also recommended to allow a clear area of 12 inches directly behind the air outlet vents. This will allow for proper air circulation in the system.
Transportation Requirements
  1. When handling the chiller, do not overturn or tilt it.
  2. When lifting, make sure that the chiller is upright and is not higher than 7.8 inches above the ground.
Note: The chiller itself is designed with lifting eye bolts, please use these lifting eye bolts.
Storage Requirements
When the chiller is not being used for an extended period, protect the interior of the machine and the condenser from dust and moisture.
  • Drain the chiller fluid and drain the fluid in the pump, filter and plumbing.
Steps of operation:
  • First shut down and cut off the power supply, and operate after 5 minutes.
  • Close the inlet and export ball valve and remove the connection pipeline between the equipment.
  • Drain the water purification/oil tank, water/oil pump, filter, plate change, water/oil inside the pipeline in turn.
  • Use compressed air to blow the internal residual liquid through each interface. It is best to blow it several times at intervals. When no liquid flows out of the interface, it is proved that it has been blown clean. Repeat until no liquid flows out of the interface.
  • Close the inlet and outlet ball valve and each drainage valve.
  • Please place this machine away from the dust.
  • Please wipe the surface of the body clean, and blow away the dust and oil from the inside with an air pump.
  • A protective cover is put on the outside of the device to prevent dust and moisture from sticking.
  • Store this machine in a flat ground, dry and ventilated place to avoid direct sunlight.
  • If the device is equipped with casters, please make sure that the casters are fixed or locked to avoid damage caused by sliding the casters.
  • Ambient temperature requirements: 0-45 C degrees, ambient humidity requirements: ≤ 90%RH
8.3 HDC-3-5AX Service Parts List
Revision A 02/2026
Service Parts List
Important: Haas Service permission is required for certain kits before they may be ordered.
PART NUMBER
DESCRIPTION
93-5381
SPINDLE CLAMPING SET HSK100A ES511
93-5373
TRP ANALOG SENSOR ES511
93-5372
TRP CYCLINDER ES511
93-5378
ENCDR NCE GEL2444M ES511 MITSUBISHI
93-5371
ENCODER CABLE EXTENSION ES511
93-5370
SENSOR CABLE EXTENSION ES511
93-5369
TRP SENSOR S5 ES511
93-5379
TSC ROTARY UNION OTT ES511
93-5380
TSC TRANSFER TUBE OTT ES511
93-5368
THERMAL SENSOR PT100 ES511
93-5619
ACCUMULATOR BOSCH HPU WORKHOLDING
93-5618
GAUGE 0-40 BAR G1/4B BOTTOM
57-0974
O-RING 1MM CORD STOCK
93-508
WAYCVR HDPE WIPER KIT X-AXIS VS-3/HDC
Note: The X-Axis Wiper Kits (93-5083) only have replacement parts for one waycover. If wipers are needed on both X-Axis waycovers, the service kit will need to be ordered twice.
57-0897 O-RING .070 C.S. CORD STOCK
AD0869
Revision A 05/2025
This procedure tells you how to replace the wipers on the telescopic style way covers. To replace the telescopic way cover wipers, you must order the correct kit. Use the parts included section below to find the correct kit. Go to the Way Cover Guide to troubleshoot the way covers.
Note: Do this procedure for the X- or Y-Axis way covers. The images in this procedure are shown on the X-Axis way cover.
Tools Required:
  • Flathead Screwdriver
  • Leather Gloves
  • Rubber Mallet
  • Mobil Grease XHP 222
  • RTV ASI 335 (P/N: 93-99-4452)
This document applies to these parts:
VS/HDC:
  • 93-5077 WAYCVR HDPE WIPER KIT Y-AXIS VS-1/3
  • 93-5081 WAYCVR HDPE WIPER KIT X-AXIS VS-1
  • 93-5083 WAYCVR HDPE WIPER KIT X-AXIS VS-3/HDC
 Note: The X-Axis Wiper Kits (93-5081 and 93-5083) only have replacement parts for one waycover. If wipers are needed on both X-Axis waycovers, the service kit will need to be ordered twice.
Tools Required:
  • Leather Gloves
  • Rubber Mallet
VS/HDC:
Replacement
Jog axis to extend way cover and press [E-STOP].
Remove these parts from the machine:
  • Telescopic way cover [1]
Caution: The way cover has sharp edges. Use the leather gloves when you handle the way cover.
Turn the way cover upside down.
Remove each section of the way cover by expanding the smallest leaf.
Apply outward pressure and rock the leaf back and forth to separate all the leaves.
Wipe off excess grease [1] and inspect the brass seals [2], plastic slides [3], and bumpers [3]. Use the mallet to remove any dents from the way covers.
Note: Bumpers were added starting September 2021. However, they are not backwards compatible. If a bumper is damaged or missing, the way covers will still function properly.
Select the wipers according to size for each leaf. There should be no cutting needed.
Inspect clear tubing before new wiper installation and make sure the length of the clear tubing is fully inserted in the proper channel of the wiper.
Install the REPLACEMENT WIPERS [A]. Put grease on the REPLACEMENT WIPERS [A]. Use the mallet to tap the REPLACEMENT WIPERS [A] into the slots.
Install each leaf one at a time by placing one edge of the leaf inside the front edge of the larger leaf, apply downward pressure to insert the other side.
Note: Use the flathead screwdriver [B] to help pry the way cover leaf to insert another leaf.
Evenly apply force over the entire cover to help compress the clear tube and slide the leaf into place.
Follow this process to install all the leaves.
Remove chips and debris from the linear guides.
Clean the table mounting surface.
Apply a thin coat of grease to the way cover guide bars [1].
Install the way cover over the guide bars.
Attach the way cover end panel to the sheet metal. Use the end [2] and side [3] fasteners.
Move the table [4] to the full X-Axis travel.
Fully extend the sections of the way cover [5]. Make sure the way cover moves correctly and is the correct length.
Lightly spray a multi-purpose lubricant onto the tops and sides of each of the way cover panels.
Move the largest section of the way cover away from the table.
Put the RTV ASI 335 sealant on the way cover where it touches the table mounting surface [1].
Attach the way cover to the table with the (10) fasteners [2].
Remove any sealant that is squeezed out of the space between the way cover and the table.
Release the [E-STOP] and press [RESET] a couple times to clear the alarm.
Check the X-Axis and Y-Axis movement to make sure the way cover does not bind.
